89 alignment
Old Feb 28, 2015 | 10:57 AM
sidescrollin's Avatar
You might have misread the specs and confused the plus or minus? The specs are, as in my post above:
Factory specs are:
Castor:3.5° positive +- 0.25°
Camber: 0.5° negative +- 0.25°
Greg
Hmmmm interesting. I was just glancing for the numbers, but looking again I definitely see the +- in my book. Adding to the confusion is the insistence on making a word sentence rather just just writing the specs.
service manual reads
Castor:3.5° +- 0.25° positive
Camber: 0.5° +- 0.25° negative
Old Feb 28, 2015 | 10:59 AM
Originally Posted by Doug
I *think* sidescrollin is referring to the change in specs as described in the 1995 TSB that he posted a link to. I wonder if Jaguar really intended that the entire XJS 20 year model run should use the specs shown in this bulletin. Seems it bit broad and sweeping to me.
I referred to both, but the second I referred to incorrectly. I was just looking for numbers and ignored the +-, and also assumed that range would be correct because the range on the tsb is so large.
So all that established, you can definitely adjust your caster some, but going off of the original specs and tsb update, it shouldn't really be a big deal.
Def fix the camber though to avoid tire wear.
MrWhite
19
Jun 14, 2022 07:49 PM
NTL1991
XJ40 ( XJ81 )
May 1, 2017 07:54 AM
jonahjob
Oct 1, 2015 07:54 AM
ahunt4
Sep 19, 2015 09:49 AM
