89 Marelli no start, no spark
Old Sep 4, 2017 | 12:13 PM
acauto's Avatar
Default 89 Marelli no start, no spark
Hello again, got the brakes working but now it shut off and will not start again. It has no spark but power at coils and injectors. This happened while idling last fall so i just put it away for the winter (I don't my classics in the Boston winters; road salt!!!!). Any way pulled it out in the spring, still no spark. removed the cap and rotor all looked good. Ohmed the cap and rotor good, tested for power at coils, good. went to test for injector pulse and the car fired right up? Been running all summer but i have not driven it due to brake issues. Thank for the help there. Drove the car locally this weekend, no problem. Pulled it out of the garage this morning to work on some other minor issues and once again it shut off while idling? Once again, no spark, no injector pulse but power to the coils and injectors. My gut tells me crank sensor(s) but i have little experience with the Marelli system and shop manuals I ordered for my 89 are for the earlier ignition system and of little use. Thoughts and sugestions would be appreciated. Mark.
Old Sep 4, 2017 | 12:21 PM
Daim's Avatar
If it shuts off while idling, then it sounds like a sensor. The front and rear sensors are both the same and are readily available. Are they the original ones? If yes, replace them. I cam't remember them being expensive...
Old Sep 4, 2017 | 01:00 PM
acauto's Avatar
Are the sensors for each bank? If so is it likely they would both fail at once or do they not run on just 1 sensor for one bank?
Old Sep 4, 2017 | 01:09 PM
Daim's Avatar
No the sensors are for the full system. Iirc the front one was for the initial timing, the rear one for the TDC signal.
Old Sep 4, 2017 | 01:30 PM
acauto's Avatar
Thanks man.
Old Sep 4, 2017 | 02:11 PM
acauto's Avatar
Took the connector apart for the crank sensor up front and sure enough the terminals looked corroded. Some electrical connector cleaner and a point file later plugges it in and she fired right up. You guys are the best.
Old Sep 4, 2017 | 02:32 PM
Daim's Avatar
Glad I could help, though you basically was pointed in the right way by yourself
Old Sep 7, 2017 | 09:14 PM
saliah mohammed's Avatar
Default Xjs v12 marelli ht lead order
hi there people having problems with my xjs v12 marelli ignition bought with all soark plug leads off so now i dont know the order they go on... anyone know where 1A lead goes to on the distributor cap as the distributor numbers are not labelled right as the firing order would be??
Old Sep 7, 2017 | 10:52 PM
Daim's Avatar
Get yourself a new cap from SNG. The nonlabeled ones are of a very cheap quality.
Old Sep 8, 2017 | 03:34 AM
Thanks for your reply my after market distributor is labelled in the same order as the original marelli one..
Where would you put 1A lead to on this cap as the firing order is 1A,6B,5A,2B,3A,4B,6A,1B,2A,5B,4A,3B
The order on the cap is different.
Old Sep 8, 2017 | 04:13 AM
Daim's Avatar
The Order is different because it is leveled. Follow the numbers on the cap. That is the correct way. Not kidding.
Old Sep 8, 2017 | 07:49 AM
I tried that way for example put 1A to 1A on the cap and so on and it was backfiring like mad i mean really loud bang...
Old Sep 8, 2017 | 08:28 AM
Daim's Avatar
Did you put the coils on the correct plugs? The cables for those are easily done wrong... I have managed it myself.
Old Sep 8, 2017 | 08:45 AM
acauto's Avatar
Does this help.
Old Sep 8, 2017 | 09:30 AM
Originally Posted by acauto
Does this help.
yeah ive also followed that diagram the jaguar manual says do it this way....
But this way it dosent rev past 2000 rpm
Old Sep 8, 2017 | 09:40 AM
acauto's Avatar
The diagram you are posting is not for the Marelli system. That is the earlier system. Make sure the upper coil is going to the "B" coil post on the dist cap.
Old Sep 8, 2017 | 10:58 AM
Daim's Avatar
Exactly. Twoi different ignition systems. They are both TOTALLY different. Kind of like V6 and I6 engines
Old Sep 8, 2017 | 02:58 PM
Thanks for your replies.. the car shop gave me this book whoch goes up to 1988 and mine is 1999.. they said it would be same order but guess not as u mentioned.. will look in to getting the actual manual.. any idea where to buy from?? Thanks
Old Sep 8, 2017 | 04:44 PM
1989 sorry
Old Sep 9, 2017 | 08:31 AM
Doug's Avatar
Good reminder to check and clean connections before replacing parts
