On to the '89 - won't start
Old Aug 7, 2025 | 03:41 PM
BradsCat's Avatar
Default On to the '89 - won't start
Hi all,
As I just posted the '86 is now running correctly and is road worthy. Big victory!!
No on to the '89 that I also refurbished with new hoses, belts, plugs, wires, coil, battery, EFIs refurbished and tested, filters, brake calipers, rotors, pads, hoses, shocks, tires, fluids, , re-packed wheel bearings, etc...
The car had been sitting in a heated garage for almost twenty years and needed rescue. BRG wi/tan interior and lattice wheels. Exact duplicate of Frank Sinatra's car except he had chromed wheels. .
I have two problems:
1) The car won't start despite all the replacement parts. The car is getting spark on both A & B banks. Tested with a timing light. EFI's getting signal tested with Noid light. Fuel pump is operating. New fuel in tank (drained all the old stuff from both the main tank and auxiliary tank and new filters). Any suggestions?
2) Non working ABS. Car is equipped with Teves ABS. No power to the pump but all other electrical systems are working as designed; lights, turn signals, gauges, windows, locks. All fuses have been tested or replaced. Cannot bleed the rear brakes without a functioning ABS pump.
Old Aug 7, 2025 | 03:52 PM
ptjs1's Avatar
BradsCat,
Suggestions:
- Undo Air filters, spray a bit of EZstart into open butterflies and see if engine tries to start. If so, it's a fuel problem. So, then:
- Pull the fuel pipe connection on B Bank and, with the help of an assistant, check that fuel is being pumped to rail A, When ignition is turned on B. When engine is cranking
As regards the ABS, Do the blink test and see what error codes are thrown. Then do the 32 Continuity tests.
Good luck
Paul
Old Aug 7, 2025 | 04:32 PM
MooseOHJ's Avatar
I always forget this. Do you have a writeup by chance? Or could you make one? I'd like to add it to the Google Drive. Thanks
Old Aug 7, 2025 | 05:20 PM
BradsCat's Avatar
Blink test?
32 Continuity test?
Please elaborate
Old Aug 7, 2025 | 06:01 PM
ptjs1's Avatar
The Blink test is the Jaguar procedure to pull any ABS fault codes that are present in the system.
The Continuity tests are the Jaguar procedure to run 32 tests that identify any electrical failures in the ABS system.
Do you have the Workshop Manual? Both procedures are detailed there. If not I can try and create a document for you detailing both of them.
Paul
Old Aug 8, 2025 | 06:17 AM
MooseOHJ's Avatar
Paul
I do have the workshop manual. Haven't read it all so I didn't know it was in there. Thanks. Maybe it would be good though to make a little document explaining them? Would be a good pdf to drop to people as they ask about these tests. Anyway thanks.
Old Aug 8, 2025 | 06:50 AM
BradsCat's Avatar
My '86 is now for sale. Very reasonable. New trans, engine completely refurbished, funs great. Interior is very nice. Wire spokes. Good tires. It could use new paint. BRG w/ tan interior.
Old Aug 8, 2025 | 06:51 AM
BradsCat's Avatar
Yes, please post the Shop Manual procedures. Much appreciated.
Old Aug 8, 2025 | 12:22 PM
ptjs1's Avatar
BradsCat,
I should have the docs in pdf form. Drop me PM with your email address and I'll get them together and email to you.
Paul
Old Aug 10, 2025 | 09:24 AM
BradsCat's Avatar
PM sent. Thx
Old Aug 15, 2025 | 06:30 PM
sanchez's Avatar
Congrats on finishing the 86. Haven't heard from you for a while. Hope all is well..
BradsCat
Mar 23, 2025 07:37 AM
xjsrookie
May 26, 2023 09:35 AM
05strSATX
Sep 7, 2021 02:48 PM
Capt haddock
Mar 18, 2013 03:05 PM
bicol
XJ40 ( XJ81 )
Dec 19, 2012 12:50 PM
