89 XJS Ignition Question
Old Jan 21, 2014 | 03:57 PM
89xjsrules's Avatar
Default 89 XJS Ignition Question
about 7 years ago I bought a 50k mile near mint XJS convertible that had an engine fire. I had trouble finding all the parts but have finally tracked them down. The problem is its been covered in a storage garage 20 miles from home all this time. Now Im ready to work on it and the guy at the garage lost my only set of keys. Id like to just order a lock set and ignition tumbler. How do I replace the ignition tumbler with out destroying anything? I am an ex mechanic so dont be afraid to get technical. Unfortunatly Ive never done the XJS Before.
Old Jan 21, 2014 | 05:00 PM
Welcome to the forum 89xjsrules,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some info about yourself and your vehicle for all members to see.
In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Jan 21, 2014 | 07:29 PM
warrjon's Avatar
The ignition lock unit is fixed to the column with special security screws. Use a center punch and carefully remove the screws. You will need to replace these screws with new ones, or as I did cut a slot in the head with a Dremel. This will allow you screw the lock unit back into the column with a regular screwdriver. The only problem is the lock can now be removed with a screwdriver. I don't think this is a problem as nobody will steal an XJS (at least here in Aus)
Take a look at the last picture in this link
Jaguar XJS Restoration : XJS Steering Column Repair
Old Jan 21, 2014 | 08:09 PM
89xjsrules's Avatar
Are you just breaking the heads off with the punch? After removing the bolts that secure the column to the dash, Is there enough room in the car to dremel a slot in those bolts or is it better Idea to pull the column.
Old Jan 22, 2014 | 02:30 AM
warrjon's Avatar
I don't think there is enough room to do it in the car. I had to pull the column to repair the horn, took me about 1.5hours to have it on the bench.
To remove the screws use a punch to undo the them. Once out put them in a vice or multigrips then I used the Dremel to cut the slot.
Old Jan 22, 2014 | 05:51 PM
Bill C's Avatar
Maybe I'm missing something here (wouldn't be the first time), but wouldn't it be easier to go to a local Jag dealership with the VIN and registration (or some proof of ownership) and order new keys?
The garage might/should reimburse you for the expense.
Bill
Forcedair1
Sep 8, 2025 01:57 PM
dsnyder586
Dec 29, 2024 07:39 PM
XJsc-guy
Nov 23, 2015 01:56 PM
jagent
Sep 12, 2015 01:40 AM
avern1
Sep 8, 2015 06:25 PM
