89 XJS third light bulb holder removal
Old Apr 7, 2011 | 01:05 PM
ronvette's Avatar
Default 89 XJS third light bulb holder removal
How do you remove the part of the third brake light on an 1989 XJS hard top that has the light bulbs in it?
Old Apr 7, 2011 | 03:18 PM
Doug's Avatar
My memory is foggy on this but I think there are two tabs on the underside of the plastic housing. Push the tabs upward and slide the housing off.
Gently.
Old Apr 8, 2011 | 08:37 AM
ronvette's Avatar
Thanks for the reply. I am trying to remove the plastic part that has the bulbs in it and not the cover for the unit. I can see a metal clip on each end but can not figure out how to release them, so that the part will come off.
Old Apr 8, 2011 | 08:43 AM
Doug's Avatar
Ahhhh.
Still a bit foggy but the I think the metal clips are glued to the glass and the housing slides off off them...probably upwards.
Sorry I can't be of more help.
I was hoping someone would come along and bail me out!
Old Apr 12, 2011 | 04:12 PM
ronvette's Avatar
Default I figured it out!!!
To remove the bulb holder you have to press it towards the rear window and slide it up along the glass.
JarodL
Mar 7, 2024 01:39 AM
D.K
Dec 10, 2023 02:05 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
