90 xjs v12. Injectors not firing
Old Dec 20, 2024 | 03:19 PM
Tjag's Avatar
Default 90 xjs v12. Injectors not firing
Help
been gone awhile. Took a break from jag as wasn't getting anywhere. Cars has sat for 5 years but ran fine until head gasket went. Finished top end now won't start. I'm thinking hooked something wrong but checks out. Runs off bottle so dist system fine. Changed out cps and speed sensor. No O scope but ohms fluctuate during cranking at ecu. No tach signal..Did pin to pin of dreaded white wire from point 18 to 24 on ecus. Was good. Have 4 points of 12v to power resistor. Not sure how to test power resistor but did ohm accross each of the 4 circuits. Showed .006 ohms. Anyone know minimum sensors needed to fire injectors and how to test power resistor. Any ideas will be appreciated. Have fuel to rail.
Old Dec 20, 2024 | 03:26 PM
garethashenden's Avatar
When you say it "Runs of bottle" do you mean it runs on starting fluid? Or something else?
If that is what you mean, is there fuel in the tank? Is it fresh? Does the fuel pump run? If you turn the ignition on and then open the throttle all the way, do the injectors click?
Old Dec 20, 2024 | 03:30 PM
Tjag's Avatar
Yes using brake clean to fire. Have dioed light in 1a and fuel in tank and pump running. Fuel to rail. 12v to both injector points
Old Dec 20, 2024 | 03:32 PM
Tjag's Avatar
Have not heard click but will turn throttle
Old Dec 20, 2024 | 04:18 PM
Tjag's Avatar
Turned throttle but no injector click
Old Dec 20, 2024 | 05:07 PM
RGK20m3's Avatar
Using noid light in injector, light should be off unless cranking- 12v would be normal on both sides of injector plug if the rest are plugged in. If no flashing when cranking, almost has to be something wrong with the coax. I am not familiar with the Marelli ignition, but there has to be a coax from ignition amp to ECU.
Gatorowens
Aug 6, 2023 07:16 PM
JayJagJay
Jul 18, 2017 05:59 PM
rnoswal34
Feb 14, 2017 07:30 PM
Mort Snurd
May 11, 2016 05:13 PM
bullittandy
Apr 3, 2015 03:10 AM
