91 XJS heater core questions
Old May 19, 2009 | 05:27 PM
fippsland's Avatar
Default 91 XJS heater core questions
Is it neccessary to pull the streeting wheel to remove the steering column? Also, there is a recommendation of cutting the heater core supply lines vs. removal of the total unit in Palms' book. Any input or experience in this dept. anyone? Thanks. KFipps
Old May 19, 2009 | 09:07 PM
Doug's Avatar
Your '91 will have the Mk III Climate Control so replacing the heater core isn't too bad at all.
The pipes unbolt from the left side of the core. Then the core itself slides out through a little access opening on the right. Removing the instrument cluster helps. The details are in Kirby's book.
Old Jun 9, 2009 | 05:39 AM
fippsland's Avatar
Default more fun
Thanks Doug, as I got started I realized that the system was not the later edition, as I expected to find by VIN, but the earlier system that does require gutting the interior. I'm at the point that I need to drop the steering column, remove the steering wheel to get the dash all the way out, but cannot find info ANYWHERE on disarming the airbag before removal. So I'm in a holding pattern. Thanks for the input though. Much appreciated.
Old Jun 9, 2009 | 08:23 AM
Doug's Avatar
Don't take mine as the final word but I think the aitbag on your is the old mechanical type and doesn't need to be disarmed, although there might still be a trick to removing it. Others will chime in.
If you have a '91 XJS with the early Mark II climate control then something very strange is going on. Jaguar started using the Mark III system circa 1986/87
Old Jun 9, 2009 | 11:08 AM
fippsland's Avatar
I did find info on disarming on the Jag Lovers forums. Anybody else needs it, hollar at me.
Forcedair1
Sep 8, 2025 01:57 PM
02jagstype
23
Oct 23, 2022 07:03 PM
Saturbo
Sep 8, 2015 07:35 PM
edtexas
Sep 5, 2015 10:49 AM
pocketrocket
Sep 3, 2015 07:44 PM
