93 xjs 4.0 auto trans light on-Solutions ???
Old Apr 19, 2015 | 05:49 AM
butkusandbale's Avatar
Question 93 xjs 4.0 auto trans light on-Solutions ???
93 xjs 4.0 * auto trans light on * Solutions Welcome. Thanks!
Old Apr 19, 2015 | 06:50 AM
ptjs1's Avatar
butkusandbal
At 44k and with being laid up for so long, you're well overdue for an auto fluid and filter change. It can make a huge difference to those ZF boxes.
Do the change, reset the light, drive the car and see how it goes.
Good luck
Paul
Old Apr 19, 2015 | 03:33 PM
I'm ok with the fluid/filter change, but how do you reset light... i still have not found-out where to hook-up my scan tool ? I do have a factory service manual ... I'm in a learning curve with a Jaguar.. ' Old Corvette Guy!' Thanks!!!
Old Apr 19, 2015 | 04:02 PM
ptjs1's Avatar
butkusandbale,
Unfortunately, your scan tool won't work with your XJS. You need a Jaguar-specific PDU which plugs into a bespoke port in the boot.
However, you should be able to dump the fault code and light by disconnecting the battery for 30 mins. If the light goes out then reappears, it's because the car has "seen" the fault again.
Hope that helps
Paul
Shawn Svacha
Nov 4, 2019 02:47 PM
afterburner1
Dec 16, 2015 12:12 AM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
pnwrs2000
Sep 3, 2015 11:55 AM
King Charles
Sep 3, 2015 12:40 AM
