94 jag.xjs 4 liter (6 cyl.) No Start
Old Nov 11, 2011 | 12:46 PM
jagman94's Avatar
Default 94 jag.xjs 4 liter (6 cyl.) No Start
I have a 94 jag. xjs, 6cyl. and it will not start.I checked ign. key voltage and it has 12 volts until you move key to position 1 or position 2.Volts then drop down to 9.I have checked ignition key connector and it is good.When I add another hot wire to the key ignition wire`s,car starts and volt meter works (didn`t work before).I have a new battery and have checked relays and fuses for excess volt draw.I would like to know if I can leave this extra hot wire in the ignition system.In warm weather car would start but with difficulty.Cold weather no start.
Thanks,HarryK
Old Nov 11, 2011 | 01:35 PM
M90power's Avatar
ok, so after you checked for power, did you check for spark? now check for fuel pressure.
Old Nov 12, 2011 | 05:38 AM
jagman94's Avatar
yes,fuel is good,no spark,voltage going to coil is only 9 volts
Old Nov 15, 2011 | 07:27 PM
jagman94's Avatar
Found problem,ignition power feed wire from bulk head not making good contact.The power lead is located inside car behind dash on bulkhead (firewall).Connection felt tight but when you applied pressure to it battery voltage stayed up when ignition key was moved to position 1 or 2. Just tighten wire connection nut. HarryK
steve_k_xk
Non-Jaguar Vehicles
May 17, 2016 05:29 AM
cissdm
May 3, 2016 06:02 AM
perfectson
Nov 1, 2015 10:46 AM
deanh
Sep 6, 2015 08:20 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
