'95 XJS 4.0 Hard to start after running
Old Jan 24, 2023 | 10:17 AM
grasan's Avatar
Default '95 XJS 4.0 Hard to start after running
I have recently purchased a '95 XJS 4.0 with 86,000 miles. Beautiful, well cared for car. Starts the first time after sitting, but is hard to start shortly after turning it off. After five or six attempts it will fire and run smoothly, but has a very strong acrid fuel smell. It made my dogs sneeze when in the garage. A couple of times after multiple attempts it started, sputtered and died. Fuel pump is running, crank position sensor replaced 1,500 miles ago. It runs very quiet and smooth otherwise. Ideas?
Old Jan 24, 2023 | 12:35 PM
Vee's Avatar
Vee
Oxygen sensors not working well?
Fuel Filter clogged?
How does the trunk smell?
Assuming its a convertible?
Old Jan 24, 2023 | 12:39 PM
Greg in France's Avatar
Coolant temp sensor?
Crank position sensor?
Fuel pressure regulator?
All these can be iffy when hot.
Does flooring the throttle help?
Old Jan 24, 2023 | 12:51 PM
grasan's Avatar
Appreciate the suggestions. Will start with the easy and move from there. Will try the fuel filter first. Thank you.
Old Jan 24, 2023 | 12:52 PM
grasan's Avatar
CPS was changed recently by previous owner. Perhaps they were chasing this gremlin. Throttle position does not seem to matter. Thanks!
Old Jan 24, 2023 | 12:58 PM
ptjs1's Avatar
Coolant temp sender could be playing up causing overfuelling when hot on restart. Try disconnecting the plug and bridging the terminals on the plug. If that improves hot start, then change the sensor. Also try starting with accelerator held FULLY floored which will cut out pump. Again if that improves matters, if could be a indication of overfuelling.
If its potentially underfuelling through fuel evaporation / regulator valve dropping pressure, then you could try cycling the pump by turning ignition on and off a few times. (Pump will run for 2 secs on each turn of the ignition) if that improves the start, then you're looking at a drop in fuel pressure in the rail.
Another check is to open the fuel cap when hot. If you get a rush of air, you've got a vacuum building up which can restrict fuel flow. The vacuum would probably slowly release overnight hence cold starts are ok.
Good luck
Paul
Old Jan 25, 2023 | 05:26 AM
grasan's Avatar
Good luck
Paul
Thank you. Will provide the results when don.
benzjag
Oct 8, 2022 10:21 PM
K55XJS
Sep 27, 2021 10:29 AM
dave1994
Jun 1, 2017 04:59 PM
mirisisa
Jul 31, 2013 10:26 PM
1985TVR
Jul 29, 2011 03:27 PM
