95 XJS Gauge cluster inoperative
Old Jan 15, 2009 | 08:04 PM
philsk8ts's Avatar
Default 95 XJS Gauge cluster inoperative
Hey there, im working on a friends 1995 XJS 4.0 L6..... The tachometer, speedometer and the erm i believe the... fuel gauge does not work... Wondering if there is a specific fuse that feeds those gauges.... or if ive got a bigger issue... i looked in the book and couldnt find a gauge cluster fuse in any of the fuse blocks... so if anyone has any ideas or such! please let me know!
thanks for your time and help
Phil
Old Jan 16, 2009 | 08:45 AM
Keith's Avatar
Default RE: 95 XJS Gauge cluster inoperative
OK, you asked for ideas, and I'm not real sure, but, somewhere I've read that the grounding for the gages were a problem. The cure suggested was to add a second ground wire from the grounding area to the frame. Anyway, just an idea, at least a starting point. Good luck.
Old Jan 16, 2009 | 08:12 PM
philsk8ts's Avatar
Figured it out..... took the under dash panel out and moved a few connectors around, turns out some dingleberry left the gauge cluster connecter partially disconnected... after 15 minutes of laying on my back with a flashlight in my hand! problem solved! thanks!
phil
jagtoes
Sep 9, 2015 09:56 PM
carcycle
Sep 7, 2015 10:22 AM
1100me
Sep 7, 2015 06:26 AM
giandanielxk8
Sep 6, 2015 07:21 PM
AL NZ
Sep 4, 2015 08:39 PM
