96 xjs 4.0 idle problem!
Old Aug 22, 2013 | 05:32 PM
barefoot's Avatar
Default 96 xjs 4.0 idle problem!
have a celebration xjs and it started to tick over at around 1500 rpm do after searching on the forums I cleaned out the throttle body with cleaner and I took off the egr and cleaned that also. the air filter was pretty dirty so I took it out altogether and have ordered a new one. Once all back together I took it for a drive but it's worse than ever missing on part throttle hunting a bit and under powered and still revving high at idle. I can't see it being the air filter not being in has anyone any ideas I didn't clean the maf as its pop riveted on. I used throttle body spray cleaner and I have checked all leads are back on correctly and no leaks.
Old Aug 22, 2013 | 07:12 PM
Vee's Avatar
Vee
I had to take my 96 in to a shop that had the PDU to reset the parameters.
Other than the TPS, sounds like you hit all the usual suspects.
The Jag shop I used with the computer is located just outside of DC. Where are you located?
Old Aug 22, 2013 | 09:54 PM
barefoot's Avatar
I am near Orlando Florida I tried a hard reset with the ecu but it now won't idle below 2k so a nightmare to drive!
Old Aug 23, 2013 | 06:40 AM
Vee's Avatar
Vee
I did that too. It made no difference.
I also tried to reset the idle speed control actuator, which only worked temporarily.
1. Run engine until you reach normal operating temperature.
2. Switch ignition off.
3. Switch ignition on, wait 5 seconds, then disconnect the connector to the idle speed controller.
4. Switch ignition off.
5. Wait 15 seconds then reconnect idle speed controller.
6. Repeat two more times.
7. On last repeat, do not reconnect idle speed controller.
8. Start the engine.
Check the base idle speed, which should be at 550-600rpm. If the idle speed is not within these limits, then adjust the air bypass screw to bring the idle speed within these limits.
Switch ignition off and reconnect the idle speed controller. Start engine and check to ensure that the idle speed is between 650-800rpm.
I got this to work on my car before getting the ECU parameters reset, but when I reconnected the idle speed controller, it would fly back up to 1,500-2,000+ rpm.
Old Aug 23, 2013 | 06:46 AM
Vee's Avatar
Vee
I should also mention that my car had a sticky throttle response. It would rev high at idle and sometimes if I would tap the gas pedal, the revs would shoot up and then settle down to a rough 900rpm.
That was a separate solution. Let me know if that happens with yours.
Old Aug 23, 2013 | 10:02 AM
Vee's Avatar
Vee
I was really hoping that some day someone would have created a Jaguar PDU emulator. You know that thing was run off of a Commodore 64 or something. I'm certain the entire program could reside as a tiny iPhone app by now.
Old Aug 25, 2013 | 12:15 PM
Forcedair1's Avatar
There is a possibility that the O2 sensor/circuitry may be at issue?
Although the symptoms are not quite the same, they may be related.
Take a look at my post "O2 sensor".
Good luck,
Reinaldo
Forcedair1
Sep 8, 2025 01:57 PM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
d a
Sep 3, 2015 02:34 AM
XJsc-guy
Sep 2, 2015 11:43 AM
