96 XJS auxiliary cooling fan
Old Sep 27, 2014 | 10:12 AM
Softball60's Avatar
Default 96 XJS auxiliary cooling fan
A couple quick question for the group.
1. What signals turn on the auxiliary fan. Is it just the temp sensor? or does it go on with air conditioner on?
2. Where is the fuse and or relay located. Under the hood or in the car?
Guys
Old Sep 27, 2014 | 01:18 PM
Steve M's Avatar
Just type fan or aux fan in the search box and there will be loads of threads that you can browse through.
Old Sep 27, 2014 | 03:29 PM
Spikepaga's Avatar
The fan comes on only from a signal send by a sender in the radiator. The temperature is ridiculously high and the fan never comes in unless you modify it to come on with the a/c or with a toggle switch in the cabin so you can turn it on at will
The relay in on the U.S. drivers side in the engine bay IIRC it's the first relay in the row
Old Sep 27, 2014 | 06:37 PM
Softball60's Avatar
Thanks for the responses.
I noticed the temp on the gauge go up in city driving here in Florida. It gets pretty warm in stop and go traffice.
When I got home I checked the fan and could not get the blade to turn. Already ordered a universal type and will take it apart to see if I can fit it in the original housing.
Looked at the wiring diagram and may possibly try the connection to that when the AC goes on so does the fan.
Softball60 Paul
1996 XJS 2+2 convertible
1957 XK 140 Drophead Coupe
Every other British sports Car known to Mankind
Old Sep 28, 2014 | 12:28 PM
Steve M's Avatar
You said that you tried turning the fan, was that by hand or electrically?
Have you tried disconnecting the fan supply and powering it off another 12V supply directly? It may not be the fan at fault but the power supply.
Old Sep 28, 2014 | 07:56 PM
Softball60's Avatar
Steve,
Thanks for the input. When I checked the rotation of the fan blade I found it extremely difficult to turn....almost bound!!
With a pair of pliers grabbing on to the shaft I could turn.
These things should be almost free wheeling......???
Anyway bought another and just waiting for delivery. I'm thinking of installing a hidden switch to turn on and off as required.
Paul
Old Sep 29, 2014 | 04:18 AM
ptjs1's Avatar
Paul,
If you've got temp fluctuating in stop / go traffic, my guess would be that you've got the typical XJS cooling vanes corrosion in the lower 1/3rd of your rad.
Carefully lift the rubber flaps at the bottom and examine that section of the rad. I bet that all the road debris has corroded and blown out lots of the vanes. It happens on all late XJSs eventually. When this happens, the temp rises in traffic and then drops as you get increased airflow as you drive.
A new rad core and you'll sit happy in traffic.
Good luck
Paul
Old Sep 29, 2014 | 11:51 AM
Softball60's Avatar
Paul,
You may be correct but the issue is that the aux fan never came on. Maybe I paniced when I saw the temp creeping up on the gauge. I now know that the fan probably should have come on based on where the gauge was indicating.
As I mentioned in my previous thread, I could not turn the aux fan motor without the use of plier and force.
My guess is that the fan motor never came on when it should have.
When I drive normal in Florida (Been extremely Hot!!!) with the windows down or the top down ....No Air On..... My gauge runs normal.
Paul
Old Sep 29, 2014 | 12:38 PM
macudc's Avatar
Default This thread holds the answer to most of your questions
https://www.jaguarforums.com/forum/x...ary-fan-52343/
I made some notes (below from various posts in the thread when I had a similar problem.
"In the engine bay there's a fuse box and relay panel on the left side (there's one on
the right, too, but we want the left side)
Check the #4 fuse in the fuse panel. If blown, replace it. Should be 30amp
If the fuse is OK find the temp switch in the water pump housing. Remove the wires
and touch them together. If the fan now operates the switch is no good.
If the fan doesn't operate.......
Find the cooling fan relay near the left fuse box. It'll have brown/green, black/green,
and green/brown wires. Unplug the relay. With the relay unplugged you'll see the
wiring terminals in the plastic relay socket. Using a small jumper wire you want to
jump the black/green wire to either of the brown/green wires. If the fan now
operates you have a bad relay. If it doesn't operate then the fan motor is faulty, or
the wiring between the relay and the fan is faulty, or the ground is faulty."
Old Sep 29, 2014 | 04:05 PM
ptjs1's Avatar
Paul,
I think from your sig that you have a 4 litre. In which case the thermoswitch is in the left side upper part of the rad tank, not the water pump housing as per the v12.
Paul
silkcat
Jan 18, 2025 04:29 AM
abonano
25
Sep 25, 2015 10:43 AM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
1100me
Sep 7, 2015 06:26 AM
