Abs mil lamp always on... sigh!
Old May 11, 2015 | 03:13 PM
tommaso's Avatar
Default Abs mil lamp always on... sigh!
Hi guys!
I`m in trouble with abs.
The abs mil lamp is still Illuminated after ignition switch on without abs codes displayed.. and it stays on... with running engine too!
I renewed pads and overhaul caliper, front and rear and the system was properly flushed.
The kitty brakes, the abs pump properly charges the accumulator ball and the ball itself is new... however the lamp is always there!
Grrrrr... what's the matter?
Thanks!
Old May 11, 2015 | 04:37 PM
Vee's Avatar
Vee
Do you have wheel sensors?
Old May 11, 2015 | 11:11 PM
superchargedtr6's Avatar
If it has ABS, it has wheel sensors. Pull them out one at a time, and check them really good for the collection of debris. These things aren't sensors, they are small magnetos. They send an AC signal to the ABS control unit. As a matter of fact, there is a way to use a jumper wire, and do a diagnostic on the ABS system, that just "might" tell you exactly what it is. Another thing that will cause this, is the pressure switch on the side of where the accumulator ball is. Known to go bad. They shut the light off, once the accumulator reaches a specific pressure.
Old May 12, 2015 | 01:17 AM
Brake buster's Avatar
Originally Posted by tommaso
Hi guys!
Thanks!
don't forget that the system needs to clear the stored code after any known fault has been rectified
this can only be done by driving the car at a speed of over 15mph ,
just letting it tick over on the drive is not enough to turn off the mil light for the ABS
just a thought,,,
BB
Old May 12, 2015 | 05:35 PM
tommaso's Avatar
Ok, I found in the forum how to test wheel sensors but... how can I test the pressure switch (black top model)?
Old May 12, 2015 | 09:18 PM
snowball's Avatar
I had a problem with my '96 XJS when I got it, the ABS light stayed on. I took out the the front wheel sensor and cleaned it ( undid bottom of shock to access it and bent
an 8MM ? wrench in Z pattern to undo) Someone had replaced rotor or wheel bearing and had anti seized the armature (looks like a gear) that activates the sensor, I cleaned it through the inspection hole at back of brake. It did not go out but took a good 10 to 15 miles, then went out. The light came on again this spring, so I clean the other side, everything works great.
Snowball
Old May 13, 2015 | 06:09 AM
You must have a 89 model. That black top switch is hard to obtain. If you dig around on this site, there is a post on converting to a blue top switch that is very common, as well as came on a lot of GM models, which makes it affordable too.
MrWhite
33
Oct 22, 2015 10:29 AM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
leep123
Sep 30, 2015 03:41 PM
