abs sensor disconnect
Old Sep 25, 2015 | 10:52 PM
Dave1109971's Avatar
Default abs sensor disconnect
quick question guys,
when dropping the rear cage on an ABS car, do you unbolt the abs sensor at the hub? or is there another way that I'm not seeing
cheers
Dave
Old Sep 26, 2015 | 06:17 AM
texasscot's Avatar
cheers
Dave
I did on my 90.
Old Sep 26, 2015 | 06:35 AM
orangeblossom's Avatar
I'm not 100% Sure but I think there is a plug on the other end.
Make sure you don't go and break it, unless you've got $300 burning a hole in your pocket!
Old Sep 30, 2015 | 11:04 PM
warrjon's Avatar
The easiest way is to remove the sensor and tape both the sensor and the hole. There is a connector but its under the back seat back rest a PITA to get at.
ericjansen
Dec 19, 2021 12:20 AM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
picard
Oct 12, 2015 11:56 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
