AC Blower MOTOR vacuum not working
Old Mar 22, 2022 | 01:54 AM
yoopas's Avatar
Default AC Blower MOTOR vacuum not working
Good morning guys, maybe someone has previous experience with not working AC Blower MOTOR vacuum?
Motor itself is working, spinning, but vacuum solenoid is not working, thus not opening/closing "doors";
Is there any chance to find this solenoid somewhere new? Tried google, ebay. - but 350 EUR for used one without warranty - sounds incorrect;
Old Mar 22, 2022 | 05:24 AM
Greg in France's Avatar
Are you sure it is the vac solenoid and not the lack of a vac source in the pipe?
Old Mar 22, 2022 | 06:06 AM
yoopas's Avatar
Yes, i'm sure, if you blow/brief air via it - it goes directly - if you try with working one - its not possible - simple easy try
Old Mar 22, 2022 | 07:36 PM
paddyx350's Avatar
I had this problem several years ago. The diaphram on the drivers side blower vacuum actuator went. I sourced a generic one from the internet somewhere and adapted it. I can't recall where, it was a while ago. I had a quick look and the actuators used for turbo wastegates look very similar and are not very expensive (30-40 euro). Might be worth a try. You'll have to remove the blower though. That job can be done but it's a right pita. When putting it back in you have to hold the door on the blower box closed.
Old Mar 23, 2022 | 01:40 AM
What Paddy means is that the bottom door on the blower has to be jammed OPEN, repeat OPEN (I use a piece of wood) as doing this shuts the TOP door into the outside of the scuttle. This TOP door is the one that MUST be held closed!
Old Mar 23, 2022 | 03:34 AM
yoopas's Avatar
Thanks, got this. I'm currently in a position where im taking out Heater Box in order to change AC Evap and Heater Matrix, thus using an opportunity to check all other components. Taking out Dash was 2 hours job, but that was the easiest part...
Nevertheless, i still cannot find nothing similar to this vacuum actuator neither new or used one
Old Mar 23, 2022 | 04:12 AM
paddyx350's Avatar
I think these are the kind of thing that you're looking for. They won't be an exact fit but if you get a bit more information about size etc you should be able to find something that you can use with a bit of modification to the arm. I remember that I couldn't find the original actuator/part number after lots and lots of searching;
https://www.oldairproducts.com/product/23-5560-actuator
This is an example of what's on Amazon;
Amazon Amazon
And a quite a few on ebay;
https://www.ebay.co.uk/sch/i.html?_f...3114_&device=c
Old Mar 23, 2022 | 04:20 AM
paddyx350's Avatar
Yes.. that's it. Sorry it was a while ago. But I still remember all the swearing getting it back in very clearly!!
Old Mar 23, 2022 | 06:06 AM
paddyx350's Avatar
The part number you need is JLM1179 I think. Here is a used one in the USA;
https://www.jagbits.com/product/JLM1179-USED.html
Old Mar 24, 2022 | 01:55 AM
yoopas's Avatar
Thank you! Just ordered it! Case and topic closed i believe
sedonajag
E type ( XK-E )
Jun 1, 2022 11:49 AM
Madscott
May 20, 2020 02:34 AM
sradcock2888
Aug 16, 2018 03:28 PM
m0t0rm0uth
Interior
May 7, 2010 03:54 AM
mikeeyager@gmail.com
XJ40 ( XJ81 )
Aug 28, 2009 07:40 PM
