Access convertible top cylinders
Old Oct 22, 2020 | 07:11 PM
OldCoastie's Avatar
Default Access convertible top cylinders
I have a 94 XJS convertible with a hydraulic leak on the driver side. How do I access the cylinder? Antwerp filling the reservoir i created a puddle in front of the rear wheel driver side.
Old Oct 22, 2020 | 07:27 PM
Jagboi64's Avatar
You will need to remove the back seat and then the side trim panel. The cylinders are behind the side trim panel. It`s actually fairly easy to remove the seat.
Old Oct 22, 2020 | 07:33 PM
OldCoastie's Avatar
I was pretty sure that’s where it was. Are the lines all inside the car? I must have pulled a line off the cylinder while relocating the pump for a fuel pump job.
Old Oct 22, 2020 | 08:05 PM
Jagboi64's Avatar
I think the lines are all inside the car, I'm not 100% sure, but I believe so.
Old Oct 22, 2020 | 08:45 PM
OldCoastie's Avatar
Old Oct 23, 2020 | 06:18 PM
OldCoastie's Avatar
Found the problem. The line to the lower part of the cylinder was broken under the corner of the window.
Old Oct 24, 2020 | 09:48 PM
OldCoastie's Avatar
Have not been able to find a vendor to replace the line. Looking for repair options now.
Old Oct 24, 2020 | 10:00 PM
Jagboi64's Avatar
You should be able to repair it with a compression fitting. I have not measured, but try looking for nylon air brake line for semi trucks, it's probably very close.
Old Oct 25, 2020 | 06:06 PM
OldCoastie's Avatar
Thanks, that gives me a solid starting point.
Old Nov 1, 2020 | 09:02 AM
BradsCat's Avatar
I have the complete setup off an '88. Guessing it will be nearly identical.
Once I get it out out of the parts car, by the end of November, I can give you the entire setup minus the pump (sold) for a say $45 including the pistons plus shipping of course.
Old Nov 1, 2020 | 02:19 PM
OldCoastie's Avatar
Appreciate the offer but Im replacing the tubing with new tubing. don't want to go back in there again. The fittings are readily available standard brass 1/4" ferrule nuts . The tubing has been challenging as its 1/4' OD, 3/16' ID and rated at 425 psi. but I found an exact match on Grainger's website. Not sure your hose/tubing will work on a 94 convertible. My pump is in the trunk and the longest is 96". Of course thats the one that broke.
Thanks for the offer.
Chuck
Old Nov 3, 2020 | 07:52 PM
OldCoastie's Avatar
Found an exit match for the hydraulic tubing from Grainger. 1/4' OD and 3/16" ID rated for 425 psi. that and 1/4' compression fittings with nylon ferrule and the copper insert to keep the line from collapsing at the nut. Total cost including shipping under $50. And I have enough tubing left over to do the whole setup again.
Going to try and fill the lines my manually opening and closing the top a few times before I energize the pump.
Old Nov 3, 2020 | 08:23 PM
Jagboi64's Avatar
When I had to bleed my system I filled the reservoir at the pump, then opened and closed the top. Filled again and repeated, and it seemed ok. The system seems to self bleed simply by operating the top.
The proper fluid is aircraft hydraulic fluid 5606. Cheapest place I found it was Aircraft Spruce. Doesn't matter if you get the A or H spec, get whatever is cheaper.
Dennis07
Aug 13, 2020 08:40 PM
Softball60
Jun 22, 2020 01:22 PM
lonejag
Jun 19, 2018 12:48 PM
Tri_motorman
Apr 24, 2013 02:28 PM
