Aftermarket FRP?
Old Aug 26, 2019 | 06:40 PM
VancouverXJ6's Avatar
Default Aftermarket FRP?
My fuel pressure regulators keep crapping out, does anyone here have experience fitting a quality aftermarket adjustable one to OEM fuel rail system? I know why the cars have two but....45 years later I think I can do better with the right part.
Old Aug 26, 2019 | 06:52 PM
Delete the RH more trouble than it cured.
The LH is the actual Regulator, and there are heaps of aftermarket out there, with and without a site gauge. ALL are adjustable, so you will need to set the base pressure (instructions should be in the packaging), I used 32psi on mine, vac connected and at idle. Each engine is different, so with these things you can at least ":trim" the pressure to suit.
Go for a known brand, and you should be fine.
Conversely, I have replaced the OE (LH only) with Bosch branded units, and no issues.
NO, the RH and LH are NOT the same unit.
Old Aug 27, 2019 | 01:56 PM
ronbros's Avatar
pic mine adjustable any pressure,, no primary
pic FPR
44lawrence
Aug 9, 2016 04:15 PM
adenshillito
Mar 28, 2016 10:13 AM
EZDriver
Dec 11, 2014 03:50 PM
75Gremlin
Sep 25, 2014 07:27 PM
Spurlee
Mar 26, 2011 06:23 PM
