AJ6 Cam cover gasket
Old Mar 17, 2020 | 09:09 PM
wabuegel's Avatar
Default AJ6 Cam cover gasket
I have a 1994 XJS 2+2 with the AJ6 4.0 liter engine with 51,000 miles. The original cam cover gasket developed a leak just above the exhaust manifold. I ordered a new gasket that on arrival was about an inch short when fitting it to the cover. i replaced the half moon plugs and was able to stretch the gasket and reinstall the cover. after about 50 miles the gasket blew out near the cam chain area. i ordered another gasket (still needed stretching) and put the cover back on torqueing the screws to the required inch pounds. Again it blew out near the same area. What am I doing wrong? The surfaces are clean and i'm not using any gasket sealer or cement. Oil pressure is normal.
Old Mar 18, 2020 | 07:07 AM
jerry_hoback's Avatar
It's a rubber gasket, so you shouldn't need any sealant. Could it be the supplier? I have changed that set twice without any memorable difficulties or resulting problems. It's not a cheap set though, I remember paying about $50 for it. You're putting the gasket on the cover first, right?
You said it blew out . Was there pressure causing it to squeeze out of place? Or is that just a turn of phrase? There should be a slight vacuum inside the motor....
Old Mar 18, 2020 | 08:13 AM
Vee's Avatar
Vee
Are you using aftermarket or OEM. I've had trouble with aftermarket camcover gaskets on the AJ16 engine, slightly different than yours. Eurospare, or some other un-marked part is also too large. Paid for the OEM product and the job never went so smooth!
EsRay
Dec 8, 2017 04:42 AM
aaf8
Jun 30, 2016 09:20 AM
44lawrence
Jun 5, 2016 10:52 PM
62sunbeam
Dec 1, 2014 03:36 PM
krswen
Sep 18, 2014 06:38 PM
