Any Ideas?
Old Jul 4, 2015 | 03:45 PM
mikeburg's Avatar
Default Any Ideas?
I recently had to recore the Radiator in her XJS. I found this coil behind the grill. NO hi-tension lead though, the wires came from behind the Compressor for the Air Cond. which hasn't worked since the P.O. sold the car to us. Any Ideas? The color code is White with a black stripe, and the other is just white. The last pict. proves the car is ours, a little forlorn.
Attached Thumbnails Any Ideas?-dsc_0812.jpg   Any Ideas?-dsc_0814.jpg   Any Ideas?-dsc_0815.jpg
Old Jul 4, 2015 | 05:58 PM
orangeblossom's Avatar
I think you will find this explains it.
XJS Ignition
Old Jul 4, 2015 | 11:59 PM
OB, you are becoming the master, well done. Drinks on AL, I'll have 2.
That coil is the "auxillary coil", and is wired to the "main coil" in the middle of the V. It is wired +ve to +ve. and -ve to -ve.
If, however, the main coil has had the upgrade fitted, then this coil is redundant. Quick way to find out, will the engine rev beyond 3500 without breaking down and misfiring???.
If so, then the main coil is the upgrade, if not, reconnect that coil and try again.
Your market has the low comp engine as in 11.5:1 ratio, we got the real deal, 12.5:1, and that 2nd coil is really needed.
Old Jul 5, 2015 | 12:23 AM
There is only One 'Wizard of Oz' just remembering what you told me last time your Excellency.
Old Jul 5, 2015 | 07:57 AM
mikeburg's Avatar
Default Thanks to both of you
Thanks and I'll have a drink with the two of you when we get there!
Car runs fine, I'll look for the update and get back.
Old Jul 8, 2015 | 08:08 PM
mikeburg's Avatar
Well the Coil that is left is a Lucas, I have to figure that I need a coil, still haven't got the radiator done, a small leak.
Harry Dredge
Oct 4, 2024 05:37 PM
Razor
Aug 28, 2019 08:34 PM
49Markvman
E type ( XK-E )
Sep 21, 2015 06:26 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
rachelstr
Sep 3, 2015 12:59 PM
