Best Repair Manual on the market suggestion
Old Feb 26, 2020 | 04:01 PM
Sophi111707's Avatar
Default Best Repair Manual on the market suggestion
Hi everyone, I own 2 1994 xjs convertible with the 4.0 engine (Aj6) and I like to do my own work on them. I’m about to change valve cover gaskets and o rings but would like to know the torque specs for the bolts. So I’m Looking to purchase a repair manual. Any suggestions on the best one is greatly appreciated. I know Haynes doesn't make one for 1994 xjs but makes one for the Xj6 are they comparable on engine, transmission, suspension and rear end wise Thanks
Old Feb 26, 2020 | 04:57 PM
Mkii250's Avatar
Hi and welcome. I'm using the one shown in this link: https://www.ebay.com/itm/Jaguar-XJS-...wAAOSwCypWnsAY
and it is telling me that you are looking at 17-20 lbft for the cam cover ***'y set screws. You'll also need a half-moon seal for the rear of the cylinder head.
The 1994 XJ6 has the same engine and transmission but not suspension so the Haynes book may be of some use. You won't find a better resource than this forum though! (I'm referring to the expertise and magnanimity of other members).
Old Feb 26, 2020 | 06:40 PM
Jagfixer's Avatar
I bought the factory XJS, XJ6/12 Manuals from Jaguar some time ago. If you can find one, they have everything from Hi! to wiring schematics. Not cheap, I paid over $200 new. Also, XKs (Moss Motors) have the CD manual one each specific model, somewhere around $75-$100.
Old Feb 27, 2020 | 04:55 AM
Thanks MKii250 for the info. Will look into getting that manual. And thanks for the torque spec.
Jagfixer also thanks will do some research to get the factory repair manual can you post a picture to see what I’m looking for . Is the CD manual your referring too is that the same as the factory manual but in a cd format Thanks
Old Feb 27, 2020 | 06:14 AM
Coventry Foundation's Avatar
Sophi you might wish to see this https://www.ebay.com/itm/Jaguar-XJS-...gAAOSw7wZdmfgB
Old Feb 27, 2020 | 06:17 AM
Just noticed you have a six. There are a lot of other manuals available so you may wish to contact them. https://www.ebay.com/str/coventryfou...3017013&_pgn=2
tpicotti
Dec 29, 2017 12:06 PM
Metaxalone
Mar 15, 2016 03:24 AM
e1rfw01
Mar 26, 2014 07:55 AM
mannymux
Apr 11, 2012 06:53 AM
rama1200
Feb 7, 2010 06:49 AM
