Billdot
Old Feb 4, 2023 | 07:09 AM
Billdot's Avatar
Default Billdot
Hi, I have a XJS V12 5.3. HE 1990 car in very good nick. My left hand side mirror is loose and floppy, I have tried to tighten it but I think the thread has worn. Any ideas how to fix it. If not where is the best place to get a new one.
Thanks in advance,
Billdot
Old Feb 4, 2023 | 09:25 AM
ptjs1's Avatar
Billdot,
Do you mean that the mount on the door is floppy, or do you mean that the head of the mirror is slightly loose at the junction with the mount?
If it's the former, then the 2 screws mount to captive nut plates on the inside of the door. So you would need to verify if it is the mount screws or the captive nut plates that are causing the problem.
However, if it's the latter, then that's a very different issue and is caused by a seizure of the mirror head tube to the mount tube. I can explain how to address that, but in the meantime, do not try and turn the mirror head! You will destroy the mirror.
Paul
Old Feb 4, 2023 | 10:19 AM
Greg in France's Avatar
Originally Posted by ptjs1
Billdot,
Do you mean that the mount on the door is floppy, If it's the former, then the 2 screws mount to captive nut plates on the inside of the door. So you would need to verify if it is the mount screws or the captive nut plates that are causing the problem.
Paul
To add to Paul's reply, if it is the door captive nuts that have come loose, these are clinch nuts (sometimes called Rivnuts) and it is straightforward to replace them.
Old Feb 4, 2023 | 05:35 PM
malc4d's Avatar
For mirror try ebay or https://simplyperformance.com
Mav0199
US Central
Dec 12, 2021 08:53 AM
BritishJagLass
Jun 15, 2021 03:28 PM
Simon35
General Tech Help
Jun 10, 2018 06:17 AM
orangeblossom
Apr 4, 2018 04:02 AM
mtpckts
Jan 2, 2015 03:02 AM
