black top to blue top conversion?
Old Jul 9, 2011 | 10:57 AM
worried n confused's Avatar
Default black top to blue top conversion?
I pulled the back top pump assem out of my car and replaced it with a cleaner blue top pump assm. ends up both accum. ***** were bad anyway. so I will need to get a new one. no big deal. gonna go with the gm one. anyway now I have the backwards dash brake light issue. i saw somwhere about adding a relay to solve this issue/ any thought. when I removed the black top switch from my pump the threads came off the switch., so I guesse im not gonna use that one, thanks
Old Aug 11, 2011 | 07:45 PM
anyone?
Old Aug 13, 2011 | 05:37 AM
hoodun's Avatar
By pump you mean convertible top pump? Then you mention both accumulator *****? Not sure what your asking here. If your brake light is on it may mean the accumulator ball is bad, as you mentioned... ???
Old Aug 14, 2011 | 02:49 PM
sorry for the confusion. its the conversion on my abs pump. in kirbys book it said something about using relays to go from the nla black switch to the newer blue swtich. thanks
Harry Dredge
Oct 4, 2024 05:37 PM
WinterJag
16
Oct 9, 2015 07:49 PM
Adam Lueb
Sep 28, 2015 02:54 PM
YycXJS
Sep 7, 2015 09:58 AM
sklimii
Sep 5, 2015 06:04 AM
