The Blue Goose: Adventures of a first time Jag owner
Old Jul 30, 2014 | 05:48 PM
JTsmks's Avatar
Originally Posted by paulyling
thanks for sharing guys OB we cant take any thing back from the rig as we leave by helicopter lol! no planks of wood will fit in my little carry on bag ha ha ha. But nah, that must be a little cringe worthy to watch them jacking it up like that. Thanks Greg, i was having a read of that. So you use an FM frequency still though? cheers Scott. Many people have recommend the Kirby Palm to me. i have downloaded that and have started reading it. Good read.
You can pick up a cassette tape to mp3 adapter just about anywhere for around $14 US, I use it in my XJS and X300 works great, discreet and plug and play in 1/2 second. I use mine with my iPod and iPhone.
Old Jul 31, 2014 | 04:33 AM
paulyling's Avatar
cool thanks bud. I think i found one at JB
https://www.jbhifi.com.au/tv-home-en...reverse/13552/
Old Jul 31, 2014 | 05:51 AM
paulyling's Avatar
Hot damn I want these plates!
Attached Thumbnails The Blue Goose: Adventures of a first time Jag owner-bluegoose.gif
Old Jul 31, 2014 | 06:17 AM
orangeblossom's Avatar
Before you get your hands on Her, have you thought about changing the name of your Car to 'Sapphire' sounds a bit more 'Jaguesque' than 'Blue Goose'
Your Car, your Choice only a suggestion!
Old Jul 31, 2014 | 06:54 AM
paulyling's Avatar
ha ha nah....the name has stuck now
Old Jul 31, 2014 | 01:14 PM
Mkii250's Avatar
Correct. The signal lead goes right into the head unit's aerial port on the back, then the car aerial plugs into it. When the iSimple unit is powered up, the car's aerial signal is interrupted and does not reach the radio. So your MP3 signal is clean.
You probably know this, but I'm pedantic so I have to say it: other FM Transmitters broadcast a weak radio wave signal that the car's aerial picks up. It therefore has to compete with any radio station in the vicinity that broadcasts on the same or near frequency. Your music will be muddied by competing signals from outside.
Old Jul 31, 2014 | 01:22 PM
Mkii250's Avatar
The iSimple Tranzit IS77 was right for my XJS because I consider it a special car and wanted to keep is original. But I'm taking a different approach with my 1986 XJ6 and installing an new head unit that doesn't play CDs: Alpine UTE-52BT Digital Media Receiver w/ Bluetooth & Aux
I have already put these in the doors: Alpine SPS-410 4" Type-S Coaxial Car Speakers - Sonic Electronix but there's no bass because they're only 4" dia.
Therefore next goes in the little under-seat sub: Kenwood KSC-SW11 Low-Profile Amplified Subwoofer + Enclosure 150W
Not an expensive system but with tons of functionaity (Bluetooth, Siri connection if you have an iPhone, front inputs for USB or 1/8" jacks...).
Old Jul 31, 2014 | 01:46 PM
  #28
Flint Ironstag's Avatar
Mkii250 is onto something here. Unless you're doing concours, why not put in a modern system which will provide decent audio quality?
Those tape adapters always introduce hiss, and pick up various electrical whines from the vehicle.
The head unit he linked, if the illumination is switchable to green, would look right at home: not too flashy.
You can also check out Nakamichi and Blaupunkt for some (visually) restrained units.
Old Jul 31, 2014 | 05:34 PM
paulyling's Avatar
cool thanks for the input guys. The general concensus is too, to install it your self as i could imagine paying someone to do it might hack it.
heh Greg did you need a seperate Amplifer to wire that unit into or is it built into the head?
Old Jul 31, 2014 | 05:51 PM
  #30
JTsmks's Avatar
Originally Posted by Flint Ironstag
Mkii250 is onto something here. Unless you're doing concours, why not put in a modern system which will provide decent audio quality? Those tape adapters always introduce hiss, and pick up various electrical whines from the vehicle. The head unit he linked, if the illumination is switchable to green, would look right at home: not too flashy. You can also check out Nakamichi and Blaupunkt for some (visually) restrained units.
Hmmm, mine sounds perfectly fine in both the XJS and X300 "always" is a broad brush, one that doesn't apply to my situation, no "hiss" or " whines" in either of my Jaguars or my old Explorer. I must have just gotten the one odd ball good one.
Old Jul 31, 2014 | 09:51 PM
  #31
Mkii250's Avatar
The Kenwood? It is in the smallish category of "powered subwoofers", so it has its own amp. You'll need a head unit that has a pre-amp sub-output (two RCA females), which most new ones have but which our old Jaguar/Alpine units do not.
Anyway you might get enough bass out of your rear speakers. They're bigger than the front's, bigger than in my XJ6.
Two things to watch:
1. if you want to replace your speakers and only your speakers and are pretty sure you will not change the original radio, get 8 ohm speakers like the OE ones. If you get 4 ohm (and I recently got the impression that 4 ohm is prevalent now, but I'm no expert) then you'll lose half the radio's volume.
2. no matter what, if you want bigger better bass, you have to change the head unit. The OE AJ8600 unit in my 1992 XJS only puts out down to 100 Hz, so there isn't much bass to amplify.
Old Jul 31, 2014 | 11:45 PM
  #32
paulyling's Avatar
thanks Greg
Im not too picky really, so long as I have some tunes lol!
I'm going to give the adapator a go first and see how it goes. If its crappy ill upgrade to replacing the cassette deck itself.
Lol i remember paying $20 for a brand new album back in the day on Cassette. Just to think i dumped them all many years ago ha ha ha
Old Aug 1, 2014 | 12:09 PM
  #33
heh guys. Been doing some more pre emptive planning for when I get home.
My XJS comes with the original cassette player. I dont want to remove it so want to discretly install something that can play MP3's or better yet, work with bluetooth, that can be installed without altering too much. No fancy speakers or anything, just good enough to enjoy, knowwhataamean?
Any recommendations?
This is one of the first essentials when i get home lol!
Hi Paul
This is what I use. MP3 Player/Cassette Adapter/Charger in the Cigarette Lighter Socket.
I did buy a really nice Stereo but I couldn't find an adapter lead, so I put it in the Merc.
Old Aug 1, 2014 | 01:20 PM
  #34
Mkii250's Avatar
An advantage of this cassette adapter is that it doesn't rely on the car's aerial to get the music signal to the head unit. Therefore no interference from outside radio sources.
Old Aug 1, 2014 | 01:26 PM
  #35
Mkii250's Avatar
I know, eh. I have lots of 20-30 year old cassettes that won't play properly. They must have gotten sticky over the years?
I learned early on to buy albums on vinyl and transfer them to a good quality cassette--but only a couple of those are still working properly and I don't want to stress my cassette player so I have repurchased most on CD and turned them into MP3s.
Old Aug 1, 2014 | 01:31 PM
  #36
Mkii250's Avatar
thanks Greg
You might be pleasantly surprised. I haven't even been tempted to change the speakers in my XJS--it sounds good as is to me. I only added the iSimple is77 so I could play and charge my iphone.
Though I really consider the aeriel-defeat switch that I added to be a huge bonus and have done it in both cars.
Old Aug 2, 2014 | 04:11 AM
  #37
Hi Paul
This looks a bit of a Bargain!
oneConcept MD-410 Car Radio USB SD MP3 at the Best Price!
Old Aug 2, 2014 | 05:51 AM
  #38
paulyling's Avatar
thanks bud Ill check it out.
Heh so do you guys use seat covers? What do you reckon are the best? I live in a relatively hot climate so not sure wool is the best
Old Aug 2, 2014 | 06:33 AM
  #39
No seat covers here - I love looking at the seats - I think they are a work of art.
Old Aug 2, 2014 | 02:04 PM
  #40
Mkii250's Avatar
No need to cover my seats, and they're black. I do appreciate the seat heaters in the fall though
THB I wouldn't cover them, I'd reupholster them, maybe with German-style perforated inserts and a lighter colour.
