Bonnet (hood) latch cable routing
Old Apr 29, 2015 | 08:26 AM
scottmg's Avatar
Default Bonnet (hood) latch cable routing
Hi all.
I'm slowly returning a previous owner's bodges and shortcuts to original, but there is one I can't find any decent information on to know whether mine is bodged or correct.
My car is a 1981 late pre HE & the cable that connects both bonnet latches is an unsheathed stranded wire that is routed diagonally across the firewall from one latch to the other. Now this works just fine, but looks very Heath Robinson. The Jaguar ROM CD diagrams are often hard to see in detail & the diagram looks like it should be a sheathed cable routed differently.
Can anyone please advise what type it should be and the correct routing? Any photos would be a great help.
Thanks,
Scott.
Old Apr 29, 2015 | 11:10 AM
Greg in France's Avatar
Scott
Your suspicions are correct, it should be a sheathed cable (Bowden cable) like an bicycle brake cable. It runs straight along the firewall between the two latches. One end just fits into the RHS latch, and the other onto a nipple with a screw fitting on the LHS latch (US driver's side) to lock the inner onto the nipple on the LHS latch and adjust it to work properly.
If all is adjusted OK, then the cable from the release lever inside the cabin activates the LHS latch, and the LHS latch pulls the cross-firewall cable to release/pull the RHS latch. The latches are sprung open.
I have not got a photo to hand, but if you get stuck I'll take some, if no-one else has any. basically you just thread the outer along behind everything in the straightest path you can find!
Greg
Old Apr 29, 2015 | 11:49 PM
baxtor's Avatar
Originally Posted by scottmg
Hi all.
Thanks,
Scott.
While the cable is sheathed there is quite a bit of bare cable beyond the brackets at each end. The sheathed section is about the width of the motor.
Old May 1, 2015 | 06:36 AM
scottmg's Avatar
Default Bonnet locking cable
Thanks for taking the time to answer my question Greg & Baxtor.
That at least confirms that mine is incorrect, so now I can look at getting it back to original.
Thanks guys.
Best regards.
Scott.
hoodun
Nov 20, 2022 02:35 PM
bdboyle
Sep 16, 2019 05:58 PM
orangeblossom
Sep 24, 2015 12:56 AM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
