"Brake" dash light
Old May 27, 2014 | 05:18 PM
SeanPeterLynch's Avatar
Default "Brake" dash light
On one startup yesterday "Brake" light went on. For a second I thought it was the "Park Brake" light. Pulled parking break and then released. "Brake" light went away.
Any ideas why this happened. Always sensitive to anything that comes to brakes, so wanted to check.
Old May 27, 2014 | 06:11 PM
Steve M's Avatar
Obvious, but have you checked the fluid level?
Old May 28, 2014 | 01:51 AM
Greg in France's Avatar
Not sure of your model, but on my car the dash brake fluid warning light goes on when ignition is first switched on as part of the factory startup dash light illumination test.
Greg
Old May 28, 2014 | 07:19 AM
Bill C's Avatar
My "Brake" light was being set off each time I stepped on the brakes due to a bad Brake Accumulator. On page 457 of "The Book" you'll find more information on the accumulator, how to check it and tips on buying a replacement.
Old May 28, 2014 | 08:21 AM
sidescrollin's Avatar
on my 88 (no ABS) this light comes and goes. It has come on when I first got the car because the brakes legitimately failed, but now it just comes and goes because the sensor is crappy. I usually ignore it.
Old May 28, 2014 | 09:48 AM
Need to check fluid. Will try that for starters.
JarodL
Mar 7, 2024 01:39 AM
Jpav27
Jul 31, 2022 06:43 AM
jagent
Sep 12, 2015 01:40 AM
mrplow58
Sep 9, 2015 11:27 AM
02jagstype
Sep 4, 2015 08:20 PM
