Brake light help
Old May 31, 2011 | 08:39 PM
cadfael_tex's Avatar
Default Brake light help
Don't have my manual yet but need to fix the brake lights. What do I need to check and where do I check it? Also think I have a tail light out.
Old Jun 1, 2011 | 08:22 AM
kthrash's Avatar
Check the bulbs and the ground connection behind all the covers in the trunk lid. I would also check the relays for the lights.. I had a relay that was corroded under the hood that once cleaned worked great. If you dont have a manual let me know and I will look up the proper relay. Do you dash lights work?
Old Jun 1, 2011 | 12:17 PM
Figured out why the one tail light wasn't working - was dangling out side the socket it goes in. Opened the boot and looked around and things weren't quite where I expected them according to what I was envisioning on a jag-lovers response I got. I think I'll take some pics of the boot and at least maybe get pointed in the right direction.
Old Jun 3, 2011 | 10:24 AM
UPDATE: Finally got the tools and mind together to check everything out. Checked out the relay in the boot and I believe it's bad. Had continuity on pin 85 with the brake pressed, had voltage on 30 and 86, but did not have voltage on 87 with the brake pressed. This, so I'm told, idicates the relay was bad. None available locally so I ordered online. Even with overnight shipping, won't be here until Tuesday Hopefully that is the answer
Old Jun 3, 2011 | 01:11 PM
kthrash's Avatar
There is a relay under the hood if I am not mistaken that is not used.. I swapped it out for a spare.. I think it was for the fog lights I dont have..
Old Jun 3, 2011 | 04:35 PM
The relay didn't fix it. Went back to the ground idea. There is a disconnected eyelet on the right rear near the lights. It is still connected on the ground end, could it be the stop light ground. If so, where does it connect?
Old Jun 4, 2011 | 05:55 PM
Ended up being a fuse after all. Fresh Spare and voila - I stop legally.
H20boy
Dec 24, 2024 03:23 PM
mbergen
Oct 23, 2019 10:26 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
motorhead69
Sep 9, 2015 10:04 AM
