Brake Lights not working but fuse not blown under dash
Old Jul 13, 2013 | 05:01 PM
Famous Jerry's Avatar
Default Brake Lights not working but fuse not blown under dash
I need to know if there is a relay I'm not finding, or inline fuse I'm not recognizing in the trunk? I have a service manual that shows one on each side, just not seeing them.
Old Jul 13, 2013 | 06:12 PM
AllanG's Avatar
What year is your car?
On my 94, there is a brake light switch on the brake pedal assembly.
There is a brake light fuse in the passenger side fuse block which is under the right side dash.
There is a brake light relay in the left rear trunk panel. The relay is blue and is above the ABS module.
Hope that helps.
Cheers,
Allan
Old Jul 13, 2013 | 06:17 PM
on edge's Avatar
Early XJS had a small 3pin relay on each side of rear inner guard screwed to a panel on the boot or trunk rubber lip. you will need to remove side covers to locate them.you may not see them but if you reach up you should be able to feel them .hope this helps
Cheers Ray
MJ'S Jag
Nov 10, 2022 08:14 AM
Stigram
Jun 17, 2022 12:05 PM
gene1
Sep 3, 2015 08:04 PM
tonydbaker
Aug 30, 2015 11:02 PM
gene1
Aug 27, 2015 09:35 PM
