brake pedal switch
Old Sep 21, 2020 | 02:09 AM
rgp's Avatar
rgp
Default brake pedal switch
the cruise control brake pedal switch, my cruise was working fine then it stopped last year, when i checked the brake pedal switch it needed moving in a good 3/8". it hadnt vibrated loose or the wiring would have been wound up,.is there anything that could have caused this to need such a lot of adjustment? i note that part no DAC1895 is a switch for a series 3 but i cant find one out there for sale, anyone know a source
Old Sep 21, 2020 | 08:03 AM
Doug's Avatar
The innards of the switch have been known to wear out and come slightly adrift (causing the contacts to flop against the metal casing....causing a short).
Not sure if this explains your adjustment mystery
Old Sep 21, 2020 | 08:18 AM
rgp's Avatar
rgp
Yes it's weird. I was wondering if whatever it's moved by has come adrift, but I can't get in with door wide open to lay in there at the moments.
Old Sep 22, 2020 | 06:03 PM
equiprx's Avatar
Sometimes the switches used are identical to off the shelf micro-switches.
That is the case for the transmission kick down switch on my 94.
If you can get a pic with a tape measure for scale I can try to direct you.
Old Sep 23, 2020 | 03:47 AM
rgp's Avatar
rgp
jaguar land rover sent me this extract from the archives, but the adjusted one is now operating correctly so i dont really want to disturb it. thanks for your input
Asdrewq
Jul 22, 2020 05:51 AM
Norbert Rman
Sep 29, 2018 01:45 AM
mark1210
Nov 1, 2017 11:41 PM
Jon89
Feb 6, 2017 06:15 PM
al5001
XJ XJ12 ( X305 )
Oct 9, 2012 09:51 AM
