I don’t know. Maybe 500hp? I’m surprised they are using standard efi intake manifolds on such an expensive engine even if they are ported. I can’t imagune they match the flow capacity of those group 44 heads.
Had no idea such an outfit existed in Austin. No power figures listed, not even conservative estimates. Man, that's a lot of $ but people must be spending it!
i have visited there shop out on 71 north, around 2006!
very nice place, but when speaking with desk person about V12 XJS, they said they specializes in E types only, kinda cold vibes!
i know i can do the same BASIC engine work for around 10K, using local Austin machine shops, and include forged custom pistons of personal design!
but i'm gettin older, so time frame would be tedious.
That maybe true but it will be very interesting to see what combustion chamber they come up with. I’m no expert but apart from flow I’m thinking combustion efficiency is also important.
i like the combustion chamber on top of the piston,thats where the push should be!
BUT many engines have chamber in the head, but heat is wasted there and overheated chambers does NOT control Detonation well!
today forced induction is the realistic way to go,IF horse power is needed and efficnciy is required, and Direct chamber injection used, along with 4 valve twin cams!
lets face it if you were to cast and machine NEW heads thats the way to go!
some times beating a dead dog is a waste of money!
You will also need to to change the spark plug position as it is high in the exhaust pocket. Bringing it down will then interfere with the exh valve head.
Yes, the blog says they are moving the spark plug position. I’m not sure why they didn’t weld up the original position before surfacing the head.
