Build thread for 7.3L V12 with Group 44 heads
Old Mar 23, 2018 | 10:56 AM
LongJohn's Avatar
Default Build thread for 7.3L V12 with Group 44 heads
2189
For those that are interested...
Not it’s not mine😞
Old Mar 23, 2018 | 06:03 PM
ronbros's Avatar
Nice find , shame its not yours!!
what would you guess the TOTAL cost, in USD ?
Ron
Old Mar 24, 2018 | 08:25 AM
LongJohn's Avatar
I would guess the final running engine with extractors, ECU, tuning, etc about 50K
Old Mar 24, 2018 | 11:16 AM
Flint Ironstag's Avatar
What kind of #s are they forecasting?
Old Mar 24, 2018 | 12:18 PM
LongJohn's Avatar
I don’t know. Maybe 500hp? I’m surprised they are using standard efi intake manifolds on such an expensive engine even if they are ported. I can’t imagune they match the flow capacity of those group 44 heads.
Old Mar 24, 2018 | 03:48 PM
ronbros's Avatar
i'm thinkin by the time its in a vehicle and running $100K.
should do better than 500hp , but either way torque should be outstanding, 7+ L should easily around 650+ lbs ft.
and they don't say about higher flow heads, the power in the jag V12 is in the cylinder heads
yup ;i bet we could pass some one with that!
Old Mar 24, 2018 | 04:26 PM
Edelweiss's Avatar
stage2v12
Old Mar 24, 2018 | 05:15 PM
LongJohn's Avatar
My 50K estimate was for the engine, not sure about the car.
Classic Jaguar is in Austin, you can pop in and ask... Maybe organize a group buy😂
Old Mar 25, 2018 | 01:09 PM
Had no idea such an outfit existed in Austin. No power figures listed, not even conservative estimates. Man, that's a lot of $ but people must be spending it!
Old Mar 25, 2018 | 01:42 PM
ronbros's Avatar
i have visited there shop out on 71 north, around 2006!
very nice place, but when speaking with desk person about V12 XJS, they said they specializes in E types only, kinda cold vibes!
i know i can do the same BASIC engine work for around 10K, using local Austin machine shops, and include forged custom pistons of personal design!
but i'm gettin older, so time frame would be tedious.
Old Mar 25, 2018 | 02:41 PM
ronbros's Avatar
reread head work , he does give specs of the 44 heads, amazing work.
probably amazing price!!
Old Mar 27, 2018 | 04:50 AM
xjsv12's Avatar
Black bearing? What who is it? Very interesting.
Old Mar 27, 2018 | 04:48 PM
ronbros's Avatar
i know that both KING bearing and Mahle have coated bearings , BLACK.
i have used King bearings ,altho they were Aluminum steel backed, lot like the early HI performance Corvette 327 FI. Moraine 400.
no longer available.
Old Mar 27, 2018 | 07:34 PM
LongJohn's Avatar
This is going to be interesting... welding up and reshaping the combustion chamber on HE heads
Megasquirt as well.
2240
Old Mar 28, 2018 | 12:07 PM
ronbros's Avatar
will never get an HE head to flow like 44 heads!
Attached Thumbnails Build thread for 7.3L V12 with Group 44 heads-img-tullius-interview-2012_0002.jpg
Old Mar 28, 2018 | 04:35 PM
LongJohn's Avatar
That maybe true but it will be very interesting to see what combustion chamber they come up with. I’m no expert but apart from flow I’m thinking combustion efficiency is also important.
Old Mar 28, 2018 | 06:40 PM
ronbros's Avatar
i like the combustion chamber on top of the piston,thats where the push should be!
BUT many engines have chamber in the head, but heat is wasted there and overheated chambers does NOT control Detonation well!
today forced induction is the realistic way to go,IF horse power is needed and efficnciy is required, and Direct chamber injection used, along with 4 valve twin cams!
lets face it if you were to cast and machine NEW heads thats the way to go!
some times beating a dead dog is a waste of money!
unless of course you just want to amuse yourself!
Old Mar 29, 2018 | 03:14 AM
warrjon's Avatar
Megasquirt as well.
2240
You will also need to to change the spark plug position as it is high in the exhaust pocket. Bringing it down will then interfere with the exh valve head.
Old Mar 29, 2018 | 09:34 AM
LongJohn's Avatar
Yes, the blog says they are moving the spark plug position. I’m not sure why they didn’t weld up the original position before surfacing the head.
Old Mar 30, 2018 | 05:07 AM
warrjon's Avatar
Hey XJSV12 why don't you lighten those rods. You can take 100g off each rod with no ill effect.
V12 race rod on the left, this was from a 600hp 7500rpm engine. Stock rod on the right.
One of my rods, lightened nearly 100g and balanced to ±0.2g
