building a 6.8 ltr v12
Old Nov 1, 2013 | 05:55 PM
  #101
ronbros's Avatar
gotta love that torque,, OH YEAH!!!
silly old saying,, "HP sells cars Torque wins races"
Old Nov 1, 2013 | 10:54 PM
  #102
88-xjsv12's Avatar
Verryyy true ronbros!
Old Nov 2, 2013 | 11:19 AM
  #103
calvindoesntknow's Avatar
that's a big advantage of forced induction especially roots blowers, is the massive amounts of low end torque
Old Nov 3, 2013 | 11:27 AM
  #104
ronbros's Avatar
cal its nice to see that you finally are becoming more aware of Forced induction!
my dad was no great car mechanic, but he said to me, back in 1952, that the best way to make engines make more power, you have to have some pressure in the inlet manifold!
as you know,by now, most modern cars are using some sort of forced induction.
a pressurized inlet system becomes less prone to problems of twists and turns,or humps and bumps in the manifolding and piping.
recent tests show that the velocity in the inlet ports actually slows DOWN when measured with very accurate testing equipment, as the boost pressure increases!!
HUH! what you say, guy says simple, the air DENSITY increases and becomes heavier so less speed but far more weight of Oxygen in the flow, and as you should know, its the oxygen content of the air is what we are looking for more power!
ALAH! NOX Nitrous, or forced induce, or the magic of Nitromethane, which carries its own Oxygen that is released when combustion occurs!
when done properly, makes a 100hp engine make 1000hp, LOL,LOL.
be OK for you, seeing as reliability is no problem for you!
Old Nov 3, 2013 | 06:57 PM
  #105
I don't mind blowers, but I'm not a turbo fan, just too slow on the throttle response and bottom end is always lacking. but for this car I wanted a bigger displacement high revving all motor set up to keep it feeling like a jaguar
Old Nov 4, 2013 | 01:38 AM
  #106
88-xjsv12's Avatar
that is the exact fear i have calvin ive been doing a bit of reaserch(ok alot shoot me) i guess there are a few gadgets out there that hold air and release it when your coming off from low rpm it supplies the motor 5psi too get things rolling again. by the way i apologize for thread hijacking you earlier haha that was not my intention.
Old Nov 4, 2013 | 02:16 AM
  #107
warrjon's Avatar
A properly engineered turbo installation is not all top end power with nothing down low. I drove a 2L Audi A4 a couple of months ago and it performed like a larger engine. It would pull up a steep hill loaded with gear and 2 people in top gear. Very impressive.
The problem is using a turbo that is too large and/or too low CR. Sizing correctly is the key. I think a 6.xL V12 with 9:1 CR and a turbo with low boost would be a great road car.
I did once have a turbo Nissan 3.0L I6 that ran 22psi of boost and it was as you described with no low down grunt. My last turbo car was a Subaru WRX and it was a great car with good low down torque (from a 2.0L), smaller turbo made a difference.
Old Nov 4, 2013 | 04:57 PM
  #108
88-xjsv12's Avatar
the trick is too get it too spool quickly as smaller turbos do holset turbos are known for their ability too spin up so ive been looking into them they are quite capable of more with a variety of modifications . im going for two holset hx52s with billet internals and fully polished.
Old Nov 4, 2013 | 11:00 PM
  #109
turbos are very hard to get right, and they do have a slower throttle response than an all motor, when trying to build a lot of power
my mother drives an Audi A4 s line with the 2.0 and it doesn't have the lag but it doesn't produce much more power, than the naturally aspirated version.
where as my best friends grand national has a 3.8 making 550 and it's got a lag that can rip your face off
Old Nov 6, 2013 | 10:57 PM
  #110
another update on the motor, got both heads bolted down and timing chain on, so all I need is the timing cover and the oil pans then I'll be ready to bring it home
Old Nov 7, 2013 | 09:18 AM
  #111
Old Nov 7, 2013 | 09:20 AM
  #112
So there are some of the pictures of the motor coming together, and there is a picture of the fj40 I'm working on at work, and there in.the backpack is how I manage a full time job motor work and college at once
Old Nov 7, 2013 | 06:20 PM
  #113
ronbros's Avatar
looking good.
think you will make 500hp, N/A??
Old Nov 7, 2013 | 06:31 PM
  #114
at this point Ron, it will make whatever it makes
Old Nov 11, 2013 | 12:46 AM
  #115
88-xjsv12's Avatar
looking good man!
Old Nov 11, 2013 | 09:46 AM
  #116
Jeh's Avatar
Jeh
I'm thinking it will make awesomeness in large quantities when it's up and running.
Subscribed.
Old Nov 11, 2013 | 05:29 PM
  #117
ronbros's Avatar
JEH, interesting in your comment "when its up and running".
and very true, a JAGUAR car is a mystical thing. they can take possession!
Old Nov 11, 2013 | 05:36 PM
  #118
ronbros's Avatar
some old pix from 1995,my engine on stand!
sorry to hi-jack.
Attached Thumbnails building a 6.8 ltr v12-jaguar-engine-build-process-001.jpg   building a 6.8 ltr v12-jaguar-engine-build-process.jpg
Old Nov 11, 2013 | 08:31 PM
  #119
back for another update, got the oil sump system all assembled. I need a front seal before the timing cover goes on. but the motor is coming along smoothly, the thing should be on.the road before Christmas
Old Nov 12, 2013 | 10:14 PM
  #120
Jeh's Avatar
Jeh
Yes these things take time, but you have gotten off the bench race it to the nuts and bolts of the build.
I'm really happy with my 4.0 but I do have to admit that se of the horses have left the barn and it makes me miss my Modified Volvo and want more power.
