C39515 Spring needed
Old Feb 7, 2024 | 02:38 PM
Segfault's Avatar
Default C39515 Spring needed
Little spring, big trouble. This is the clutch pedal spring which is supposed to make engaging the clutch less physical. Mine went into pieces. After asking all part sellers I could find the answer is "not available".
If anyone has any idea if some other spring could fit I'd be most thankful. Maybe someone has an unused pedal box with this spring still inact?
Old Feb 7, 2024 | 03:43 PM
jal1234's Avatar
That's just a pedal return spring (and is called that in the parts manual), not a helper spring. Not necessary if everything in the clutch hydraulic system is up to snuff.
Jon
Old Feb 7, 2024 | 03:51 PM
Segfault's Avatar
Thanks. Then it must be the new cylinder which must be lesser diameter, thus making the clutch harder to press. Damn, my old cylinder only needed a rubber ring which the manufacturer said is out of stock as obsolete. Perhaps I should have been more creative and repaired the old one instead of buying a new. Was overpriced, too. Could have saved some $600.
Old Feb 8, 2024 | 06:20 AM
Mguar's Avatar
A smaller diameter cylinder will be easier to push not harder.
Old Feb 8, 2024 | 10:16 PM
baxtor's Avatar
l assumed he changed the slave cylinder, not master. Just a guess however.
rod9669
Mar 13, 2023 06:18 PM
adenshillito
Apr 16, 2021 10:01 AM
Segfault
Oct 4, 2020 08:08 AM
iansane
16
Aug 20, 2020 04:36 PM
JeffR1
Mar 8, 2016 10:53 AM
