Can Finally See My Gauges at Night!
Old Apr 19, 2014 | 10:58 PM
inertian's Avatar
Default Can Finally See My Gauges at Night!
My dash gauges barely lit up when I got my XJ-S. Not surprisingly, four of the five original 3w bulbs were shot when I pulled the control cluster.
The green plastic bulb covers looked to be in good shape, so I just cleaned them a bit and installed 194LL (5w) bulbs. I could then see my speedometer somewhat if it was really dark out, the barrel gauges a little better, but the tach was still mostly dark (only one bulb there).
I did some research and purchased v12s.com LED Gauge Illumination Upgrade in green. This time I pulled the bulb covers, as they obviously were not passing enough light. Two of the covers required the removal of the speedo and tach, which was surprisingly easy to do. Cleaned all contacts and tightened all connections while I had things apart.
The installed LEDs make a huge difference. Even with the dimmer control on minimum all gauges are plenty bright and readable.
I also changed the gear selector indicator, lighter, and console pushbutton switch bulbs to LEDs. The gear selector indicator is clearly visible even in bright daylight, the cigar lighter is about the same brightness, and the console pushbuttons now show their green (off) or red (on) status, but just barely (because of the nature of the switch, no fault of the LED).
You could probably find less expensive LEDs, but the installation process was straightforward, and the LEDs work regardless of their orientation in the sockets.
Attached Thumbnails Can Finally See My Gauges at Night!-20140413_195505.jpg   Can Finally See My Gauges at Night!-20140413_195554.jpg   Can Finally See My Gauges at Night!-20140413_195559.jpg   Can Finally See My Gauges at Night!-20140413_195604.jpg
Old Apr 20, 2014 | 01:43 AM
Flint Ironstag's Avatar
Always wondered about the v12s.com gear. Thanks for sharing your experience!
Also - I just LOVE the barrel gauges. Does any other vehicle use them?
Now fill 'er up and go for a drive
Old Apr 20, 2014 | 04:39 AM
rgp's Avatar
rgp
looks good, def. better than standard
Old Apr 20, 2014 | 10:47 AM
01Silverstone's Avatar
Very nice upgrade indeed. I'd looked at their site as well before, but its nice to see someone has had a good experience with their products. I'm considering ordering the white LEDs for the dash.. might make it even brighter! Thanks again!
Old Apr 20, 2014 | 05:35 PM
M90power's Avatar
shoulda got red. nice upgrade though. looks like some spec-ops type stuff
Old Apr 20, 2014 | 11:50 PM
Yeah, I've had a couple of E38 BMWs that had some really crisp deep orange / nearly red instrumentation. Very very nice at night without affecting your night vision. Green is one of the worst colors for nighttime illumination, but it looks so good on our dashboards and vintage Alpine head units with the big square buttons.
99xk8guy
May 28, 2024 09:36 PM
danke
May 29, 2023 01:01 PM
TreVoRTasmin
Sep 18, 2015 06:57 PM
TreVoRTasmin
Sep 16, 2015 08:14 PM
