Can someone with a 3.6 manual post driving impressions?
Old Aug 15, 2015 | 12:02 AM
Broken_Spanners's Avatar
Default Can someone with a 3.6 manual post driving impressions?
In regard to clutch weight and general driveline clunkiness / feedback (or lack thereof). Gear ratios, diff ratio and RPM at 75 would be fantastic too.
Appreciate any help.
Thanks,
Jeff
Old Aug 15, 2015 | 07:27 AM
leep123's Avatar
Hi Jeff,
Bought mine about 2 months ago - a 1990, 3.6 manual. So first impressions only and as mine has done 135k my transmission may be worn.
Sat in several and they all seem to have a heavy clutch pedal compared with modern cars. At first it was a bit of an effort to use in traffic but I've got used to it. Also you only have to dip the clutch slightly to change gear which helps.
First gear is very low but once you get moving you only really need 4th and 5th as the car has bags of torque so you can drive it almost like an auto on open roads - this is also a help with the heavy clutch. I once pulled away at a junction in 3rd thinking I was in first and the car did not protest.
The gear lever moves a very long way between gears (especially 1st to 2nd etc.) so this is no fast action sports gear change but I've had lots of fun driving country roads swapping gears. To me they are more engaging to drive than the autos, you feel more in partnership with the car but not everyone will agree I know.
Not noticed any clunks in the drivetrain although my gear lever wallows about over bumps so maybe my gearbox supports are a little soft. I will check rpm at 70 next time I am out but from memory it is not high - a shade under 3000 maybe.
Are you thinking of buying. Would be interested to hear your thoughts if you do.
Cheers,
LeeP
Old Aug 15, 2015 | 09:46 AM
Thanks Leep! I'm in the process of bagging the turbo 400 and trying to determine if I want a more period trans or a later unit. I have a 5.3..
I just about bought a Federalized 3.6 manual last year that was local, and I believe the car is still available, so I may just go for it as an addition!
Congrats on your new car and have fun!
Jeff
BrentGardner
29
Dec 16, 2024 12:13 AM
philwarner
Dec 6, 2021 07:13 AM
GuernseyJag
Nov 8, 2017 10:40 AM
ControlIssues
Sep 3, 2015 07:38 PM
Terencex
Aug 26, 2015 08:47 AM
