Changing wheels
Old Mar 15, 2015 | 02:22 PM
drbill's Avatar
Default Changing wheels
I have another thread about using spacers when switching from the stock XJS wheel to and early XK8 wheel. I found this handy device to check the differences and fit. According to this, may not need a spacer at all.
Stock wheel: Diameter: 15", width: 6.5", ET: 28.5mm
XK8 wheel: Diameter: 17", width: 8", ET: 33mm
Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
Old Mar 16, 2015 | 12:40 PM
86jag's Avatar
The xk8 wheels will run on the front when turning at max lock without the spacer. If you get a spacer make sure you use a hubcentric spacer.
dsnyder586
Dec 29, 2024 07:39 PM
hunter34
19
Sep 14, 2022 11:09 PM
prettydaim
Mar 28, 2021 07:47 AM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
