Cherry Blossom - Restoration 1990 XJS V12
Old Feb 4, 2017 | 07:11 PM
  #641
orangeblossom's Avatar
Hi Brad
Yes! I'll keep you posted, just found some Pirelli on ebay £159 each (we're getting there)
Old Feb 4, 2017 | 07:19 PM
  #642
Found a High end PC in a Charity Shop
1 TB HD 8 Gig Ram AMD Quad Core (Water Cooled) High end Gaming Card Triple HDMI Coolermaster Case (weighs about 112 lbs)
Should come in handy for posting on here and only £130 which was too good to turn away.
Old Feb 5, 2017 | 04:04 AM
  #643
Daim's Avatar
Here, if you fit tires with a lower rating, you need a sticker in your instrument cluster saying no more than so and so kph. In T casing 190 kph. As an S itbshould be less like 160 kph (haven't got the rating in my head but the speed is lower). If you drive faster, it is your fault if something happens.
Old Feb 5, 2017 | 04:11 AM
  #644
Hi Daim
I had a bit of a feeling that it could be something like that but even so I do tend to feel that Tyres and Brakes are things that you don't skimp on, so if I have to pay £150-£200 a piece, then so be it.
That's why I fitted New Calipers and re Plumbed all the Brake Pipes, so 'el cheapo' Tyres would be a big mistake.
Old Feb 5, 2017 | 04:20 AM
  #645
Daim's Avatar
My idea is always: the tires are your only contact to the road. If you save money there, you reduce your contact and therefore grip to the road making the car more liable for accidents or better incidents.
Old Feb 5, 2017 | 04:51 AM
  #646
warrjon's Avatar
Agree with this, also check with regulations, in Australia it is illegal to fit tyres with a lower speed rating than is specified for the vehicle.
If in an accident insurance companies can refuse to pay if your vehicle is not road worthy.
Old Feb 5, 2017 | 05:06 AM
  #647
Hi Warrjon
I don't know for sure (maybe someone who does will chip in) but I have a feeling the same applies in the UK.
Where your Tyres must be capable of the maximum speed of the Vehicle, even if you never go anywhere near that limit.
Old Feb 5, 2017 | 05:34 PM
  #648
Hi Please could someone give me the outside diameter of the Engine Oil Sump Plug or the inside diameter of the Engine Oil Sump Plug Washer.
So I can order some new Sump Plug Washers.
Old Feb 5, 2017 | 09:37 PM
  #649
paulyling's Avatar
I just went and squeezed under my car and popped my largest spanner on mine (18mm) and it was too small.
I think it is something between 20-22mm. Someone will know off the top of their head I reckon real soon OB....
(I really need to get some larger spanners....shifters/cresent wrenches can make nice bolt heads messy)
Old Feb 6, 2017 | 02:31 AM
  #650
Hi Bro
It wasn't the Nut Diameter I needed but the size of the Thread, so I know what Engine Oil Sump washers to order.
But thanks for looking anyway.
Old Feb 6, 2017 | 04:11 AM
  #651
paulyling's Avatar
Oh no worries bud!
Old Feb 6, 2017 | 01:37 PM
  #652
Jonathan-W's Avatar
run a bit coin miner on it!
make a buck!
Old Feb 6, 2017 | 07:59 PM
  #653
make a buck!
Hi Jonathan
At the risk of showing my ignorance I do not have any idea what a 'bit coin miner' is.
I just bought it as it was a bargain and something that I use to earn a living, where I can keep my old one as a Spare.
So its really overkill for what I use it for but on the Plus side its blazingly fast and also purrs like an XJS instead of sounding like an old tin can.
Old Feb 7, 2017 | 01:50 AM
  #654
Daim's Avatar
Bitcoins are an expensive currency. They don't physically exist. You get them by providing computerpower to certain facilities which can then use your computer for tasks many and really many TB of ram and GHz of processing power is needed. For that though your computer has to run 24/7.
A bitcoinminer is kind of like a computer working for you. One bit coin will take a while to generate BUT a bitcoin is currently worth MORE than £800! And all it is is computer power which you can turn to cash...
Old Feb 7, 2017 | 06:01 AM
  #655
Hi Daim
Cheers!
In that case I think I'll need a bigger Computer!
Old Feb 7, 2017 | 07:58 AM
  #656
Daim's Avatar
OB,
you mentioned somewhere along the lines, that you had your radiator recored... I would want that done to mine (has been JB welded in a few spots by previous owners and I don't like that). Where did you have it done and how much was it?
German "recorers" want around €800 for a recore... A new radiator costs about the same...
Cheers!
Damien
Old Feb 7, 2017 | 10:06 AM
  #657
Hi Daim
800euros OMG!
In that case I won't take you Shopping with me, as my Recored-Radiator only cost £125!
and I must say they did a really magnificent job.
Unfortunately they do not do international Shipping.
So they would be a non runner as far as you are concerned.
But if you are really thinking of having to pay that much, then you could get a Top of the Range Aluminum one at that price.
Or else your only option would be to chat and charm them like I did.
But if you want to drool, here are the Pics.
https://www.jaguarforums.com/forum/x...-122634/page5/
Old Feb 7, 2017 | 03:43 PM
  #658
Jonathan-W's Avatar
bitcoin is an electronic secure currency that is generated by the bit coin mining software and are generated 50 at a time you install the miner and it makes crypto-hashes that are used to securely move the money across the internet... when you mine you also get a turn in making 50 bitcoins
and the graphics cards you have are used to do that (more powerful than the CPU for hashing...) so what is £800 time 50 ... Hmm.... you can also join a mining team where they all kick in together and split the coins... (not as good) and there are the dedicated bit coin miner hard ware that are optimized for max Hash/sec...
yes I have bought a new al thicker radiator and yes it was 800 US and it dose work great...
Old Feb 7, 2017 | 05:11 PM
  #659
BradsCat's Avatar
Almost lost my mind this afternoon. I had an appointment today so had to take the day off work. Afterwards went to the junkyard to clear my mind. Went to the area with the two '89 XJS's.............they were gone! In a near state of despondent panic I went back to the office who looked up the status of the cars. They had been moved. Whew. With much searching I found one (never did find the second one - yet). I had much longer extension with me along with the correct Torx socket and was able to remove the AAV. Unfortunately the entire steering column including the steering wheel and instrument panel have been removed since I saw the car on Saturday.
No dawdling. I will get the headliner on Saturday no matter what the weather is even though it is not as good as the one on the other car - that I never could find.
With that one exception I have everything I need for the car now. The other stuff was just nice to have.
Dropped the AAV into a pan of boiling water to clean it out when I got home. Don't know how to tell if it works but it is much cleaner now.
Old Feb 7, 2017 | 06:47 PM
  #660
Hi Jonathan
Many Thanks for taking the trouble to supply all that info on the 'Bit Coin' thing but it is really not for me, I will leave all that Stuff to the 'Geeks' who know what they're doing.
As for my New Computer which I need for blogging on here, it is one of the best bits of kit that I have ever bought and so silent that if it were not for the lights, I wouldn't even know if it was running.
And Yes! there's a Set of XJS Wheels under the Kitchen Table, the only reason being that apart from the Bedroom and Lounge, there is no where else to keep Spares, which I happen to think is perfectly normal.
