Clock
Old Mar 29, 2024 | 12:45 PM
wardhill68's Avatar
Default Clock
My clock ,anologe, runs sporadically. I pulled it and cleaned the contacts and replace 5 amp fuse #13 . While i had it out of the dash i ran 12 volts to it direct from the battery and nothing happened. Ive read you can replace this with a trip computer ,wiring is the same. I did see an in line resister when i had it out of the dash. Any thoughts? Thanks , Jeff ‘95 xjs conv.
Old Mar 29, 2024 | 12:53 PM
ptjs1's Avatar
Jeff,
Yes you can directly substitute the facelift trip computer. It plugs straight into the wiring connector. All you have to do is get a replacement veneer. I've done the transition on my 4 litre AJ16 Convertible.
Paul
Old Mar 29, 2024 | 01:11 PM
wardhill68's Avatar
Thanks Paul , i value your responses to my ongoing questions.😊
RA110623
Oct 28, 2023 08:34 PM
JaguarDon
May 24, 2022 12:45 AM
jomo
Dec 20, 2014 05:06 AM
EastRando
Apr 9, 2014 05:32 PM
joycesjag
Oct 28, 2009 10:45 AM
