Clunking noise front end 92 XJS V12
Old May 18, 2017 | 07:20 PM
NCJagman's Avatar
Default Clunking noise front end 92 XJS V12
I'm making great progress with my 92 XJS (starts, runs, shifts and stops great) but I'm getting a clunking noise from the front end. I put on new Bilstein shocks and new tires. I suspect it's worn bushings but I'd appreciate any advise from other XJS owners who have solved the clunking.
Thanks guys.
Stephen
Old May 18, 2017 | 07:59 PM
Doug's Avatar
Worn/loose anti-roll bar links can make a racket....usually more of a rattle than thunk/clunk, though.
My experience is shocks can clunk if the lower bolts aren't *very* tight. Tighter than you'd think they'd need to be.
The diagonal brakes in the engine bay can clunk if not very tight
Loose wheel bearings can give a clunk as well
Old May 18, 2017 | 09:57 PM
malc4d's Avatar
look here
https://www.jaguarforums.com/forum/x...-again-178826/
