motorcarman
close
- Join DateDec 2009
- LocationWise County,TX
Liked:9,596 Times in 5,743 Posts
The rear hub bearings use the same preload shims that were fitted at the factory. The factory already did the hard work to set up the preload.
The fronts are just the normal 'snug-up-the-nut' and feel for play/no-play in the bearings.
