Continued crank no start
Old Oct 9, 2025 | 10:01 AM
  #121
wardhill68's Avatar
Im hesitant to mess with it . Being one handed its difficult to access much less put back together. And as i sais it was working fine in that spliced configuration origanally. Im going to focus on seeing if my multimeter can get a response from the disconnected cps while turning over the engine. Then to see if i have a solid 12 v at the #7 fuse while turning over the engine. Ill report back today hopefully
Old Oct 9, 2025 | 11:16 AM
  #122
ptjs1's Avatar
Jeff,
A fluctuating 2v on a 200v scale may be difficult to pick up as Vee has mentioned. I would try and borrow a meter that has a lower AC scale than 200v.
Paul
Old Oct 10, 2025 | 12:21 PM
  #123
wardhill68's Avatar
Iv looked around and cant even find one to buy. The all seem to be standad as 200acv as the lowest
Old Oct 11, 2025 | 10:02 AM
  #124
mghirsch's Avatar
Out of curiousity, have you remove the dash panel with the gauges? My 94 had a no start problem, turned out one of the plugs on the back of the panel had popped out. Replaced it, and bingo, it started.
Old Oct 12, 2025 | 09:33 AM
  #125
Vee's Avatar
Vee
Looks like you're looking for an autoranging multimeter...shouldn't be hard to find one.
Old Oct 13, 2025 | 03:00 PM
  #126
WayneC's Avatar
Default Have you checked the ignition amplifier?
Originally Posted by wardhill68
I ve had a crank no start issue for a few months. 1995 xjs 4.0 lhd
what ive tried so far
1. new cps
2. new plugs
3. new battery as mine would go flat after a few days
4. sent out ecu and got confirmation its communicating
5. yesterday day i pulled coil and plug from cylinder 1 and 6 separately. Positioned plug and coil upside down n top of engine so i could see a spark from the plug as i cranked the engine. I saw nothing . So assume no spark
6. checked fuses and reseated ecu and ecm relays
my observations
1. tach jumps when cranking
2. I can hear fuel pump priming. I have a full tank of gas
3. given the no spark i have not check the fuel pressure at the fuel rail. Wonder if i should anyway
My suspicions
1 my security system has always been suspect. The car only came with one key no fob but locks both doors and trunk from drivers side lock. The red led by cig lighter sometimes illuminates . The key will chirp sometimes.. my convt top has never worked by the switch. I put it down manually . Quarter windows dont work. Ive notice in the wiring diagram it is somehow tied the the security system.
can i remove the security module from the trunk area to take that system and any starting issues it may cause out of the equation
Thanks,Jeff
Have you checked the GM ignition amplifier contained in a square flat box (about 4"x4"x1") atop the left side of the engine?
Old Oct 13, 2025 | 03:02 PM
  #127
WayneC's Avatar
Actually, I'm not certain your year & model uses this
Old Oct 16, 2025 | 12:16 PM
  #128
wardhill68's Avatar
Thanks bought this waiting for it to arrive
Old Oct 16, 2025 | 12:18 PM
  #129
wardhill68's Avatar
I was told that since I have a two wire coil that I do. Can you be more specific as to its location? Thanks
Old Nov 1, 2025 | 10:18 AM
  #130
Softball60's Avatar
Wardhill68,
Any update on your no start issue?
Softball60/Paul
Old Nov 6, 2025 | 09:40 PM
  #131
WayneC's Avatar
Atop the intake manifold on the left side of the engine near the middle, should be in plain view, a black box about 4x4x0.5 inches (but again, I'm not certain if your year uses an ignition amplifier)
Old Nov 7, 2025 | 02:22 AM
  #132
Greg in France's Avatar
It is a 1995 6 cylinder car, Wayne, not a Lucas V12.
Old Nov 7, 2025 | 12:16 PM
  #133
WayneC's Avatar
Thx
Old Nov 23, 2025 | 12:49 PM
  #134
Softball60's Avatar
Wardhill68,
what is the latest? Did you ever try to retime via the info from Grant?
Softball60/Paul
Old Mar 2, 2026 | 07:47 PM
  #135
Softball60's Avatar
Wardhill68,
Did you ever resolve this issue with “ crank but no start “
thanks
Softball60/Paul
Old Mar 16, 2026 | 12:45 PM
  #136
Rick25's Avatar
Default no start
It happened to me and it turned out to be the coil. It produced spark but not strong enough to fire up the engine. Changed coils, problem gone.
Old Mar 26, 2026 | 10:29 AM
  #137
wardhill68's Avatar
Car is still at the Jaguar indie mechanic . Been there all winter I don’t think the got to it so I’m hoping after my last phone call they’ll get on it. Now my 96 x300 is experiencing the same issue. This is rediculous
Old Mar 26, 2026 | 11:08 AM
  #138
ptjs1's Avatar
Sorry to hear of your new problem, Jeff!
It's the same diagnostic issue - you either haven't got fuel coming out of the injectors, or you haven't got a spark at the electrodes. (Or stale fuel!)
Good luck
Paul
Old Mar 26, 2026 | 05:09 PM
  #139
wardhill68's Avatar
Mechanic thinks it might be a bad security module on the xjs. If I match the dpp1050/xx part number with a replacement do these still need to be programmed?
Old Mar 26, 2026 | 07:20 PM
  #140
ptjs1's Avatar
Jeff,
Seriously, just get the mechanic to do a proper diagnosis of the problem before you start buying or changing anything.
Paul
