convertible top manual operation
Old Sep 10, 2020 | 11:47 AM
scottpeterd's Avatar
Default convertible top manual operation
I am going to pickup my 1992 convertible which has been sitting for the last year in Baltimore, and drive it out to Seattle.
When I was last with the car, the convertible was sluggish opening. So I suspect low fluid level. But in case it is an electrical problem, I would live to be able to operate it manually.
I know there is supposed to be a manual/electric switch somewhere. Is it on the pump? How is the hood operated manually?
Old Sep 10, 2020 | 01:28 PM
ptjs1's Avatar
scottpeterd
Theres a lever on the top of the pump. Turn it 90 degress (its marked) to allow manual fluid bypass.
Goid luck
Paul
Old Sep 10, 2020 | 01:30 PM
Paul,
Thanks. I assume that once the pump is bypassed, the top is raised and lowered by hand, as in just grabbing it?
Old Sep 10, 2020 | 04:38 PM
Jagboi64's Avatar
Correct. Although the quarter windows are still raised electrically, hold the switch to do that.
Old Sep 11, 2020 | 05:52 AM
ptjs1's Avatar
And don't worry if it feels difficult! Its heavy and you're pushing fluid and pulling against the rams. Can feel quite awkward. Easiest done from inside the car and hold the middle of the hood front rail.
Remember the 8 second up delay on the window raise.
Paul
Dennis07
Aug 13, 2020 08:40 PM
gthawk1
Jun 18, 2020 04:28 PM
superchargedtr6
XK120 XK140 XK150
Apr 18, 2020 07:52 PM
pablomonk
Mar 27, 2018 04:11 AM
TopHatChef
Non-Jaguar Vehicles
Jun 5, 2011 09:25 PM
