Convertible top operation without parking brake
Old Sep 11, 2019 | 03:44 PM
kansanbrit's Avatar
Default Convertible top operation without parking brake
Don't know if this has been covered before, couldn't find anything, but I decided to do away with the need to be in P or N and have the parking brake on before I can operate my convertible top. I found it too easy to leave the brake on and neither of these are a requirement of my XKR top operation.
So I found the two wires (black/white, black/green) that give these signals to the top ecu, cut them and grounded them permanently via the black wire at the ecu input. Now I don't have to mess with the parking brake (or be in P or N). And I can now lower/raise the rear windows whenever I want.
Old Sep 11, 2019 | 07:08 PM
Timeisrelative's Avatar
Yes it has been done, however the "standard" wire people usually do is by the pump, same idea, same wire, different location. Basically you can just make up a jumper wire and ground it. The best part is it's completely reversible. What are you using to do your rear windows up and down?
Old Sep 11, 2019 | 11:52 PM
Jagboi64's Avatar
I did it without cutting any wires. Details in this post: https://www.jaguarforums.com/forum/x...6/#post2090470
Old Sep 12, 2019 | 04:02 AM
Yes sir, exactly what I did too
Old Sep 12, 2019 | 08:28 AM
kansanbrit's Avatar
I just use the roof switch without undoing the the handles as the factory intended but I can now do it while driving.
Old Sep 13, 2019 | 08:08 AM
So does that mean you can "accidentally" operate the top while driving? I'd be concerned about running the hydraulic pump with the latches connected, for fear of it "tweaking" something. But that's just me
Old Sep 13, 2019 | 05:53 PM
malc4d's Avatar
It shouldn't do any harm.....it will only bring the rear side windows down as designed.
pelle
Jan 25, 2018 09:16 AM
Gregory Wells
Jul 25, 2017 05:59 PM
Adam Lueb
Jul 19, 2016 12:55 PM
gkazimir
Mar 12, 2016 09:11 AM
Italianguy63
Mar 20, 2012 04:49 AM
