Coolant leaking into the exhaust, cyl. 4
Old Jan 30, 2013 | 05:09 PM
nowherefast792's Avatar
Default Coolant leaking into the exhaust, cyl. 4
Hello, I just joined the forum hoping to obtain a little info about my fathers car. I live in Boston, MA and he moved out to Utah a few years back. The car is a 1994 XJS 6 cylinder. He called me a while back saying that coolant was pouring out his exhaust in liquid form, not smoke. He took it to a shop and they said it is leaking through cylinder 4 and that they don't know if its a cracked head, block, or blown head gasket. They want to charge him 20 hours just to pull the head to find out. I am just wondering if anyone knows of a common issue of a coolant passage near cylinder 4 or maybe knows of a shop in Utah that is familiar with these engines. 20 hours to pull a head just seems a bit drastic..
Old Jan 30, 2013 | 06:16 PM
calvindoesntknow's Avatar
i think you have the unfortunate problem of not having a v12. Get one of thoes, and this will be fixed, your coolness factor will go up, and youll have plenty of other problems to work out.
Old Jan 30, 2013 | 07:44 PM
Doug's Avatar
Not that mine is the final word but no "common issues" regarding cracked heads or blocks that I know of. The occassional head gasket failure does pop up. I suppose a severely blown HG could cause this.
I agree that 20 hours *to pull the head* for initial inspection seems very high.
arskemp
Sep 21, 2015 02:19 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
