Coolant temperature sensor
Old Oct 25, 2020 | 05:47 PM
Chitty's Avatar
Default Coolant temperature sensor
My 94 xjs 4.0 runs better with TCS unplugged?
replaced: coil, thermostat, TCS, fuel filter, no corrosion on any electrical plug.
if the TCS is plug in the engine is sluggish, unplugged engine is very responsive and fast
what is going on?
Old Oct 26, 2020 | 03:58 AM
Brake buster's Avatar
i think the TCS holds the idle solenoid open for cold starting, and should modulate/close the idle solenoid when up to the desired idle setting
if the sensor is wrong it could be closing the solenoid prematurely or all the time ,
does it run well when fully up to temp even with the sensor plugged in
BB
Old Oct 26, 2020 | 08:51 AM
Vee's Avatar
Vee
Your engine is staying in open loop, so it's not relying on any of your sensors to fuel the cylinders. You are most likely overfueling the car.
I would replace the $20 sensor.
Old Oct 26, 2020 | 10:59 AM
Chitty's Avatar
CTS Is new...could i have 2 bad sensors?
Old Oct 26, 2020 | 11:06 AM
you have three coolant temp sensors, one for the ECU and one for the idiot gauge in the dash and one for the temp warning light, they are not connected
hope this helps
BB
Old Oct 26, 2020 | 11:07 AM
Chitty's Avatar
The engine, at warm up temperature, still is sluggish with the CTS plug in, Could it be something with the O2 sensor?
Old Oct 26, 2020 | 07:20 PM
Vee's Avatar
Vee
You have one coolant temperature sensor. The other two sensors monitor engine oil temperature.
Old oxygen sensors could be lazy and provide you with a sluggish responding car. When was the last time they were changed?
Old Oct 26, 2020 | 07:55 PM
Chitty's Avatar
Good point, that will be next, thanks
Old Oct 27, 2020 | 01:08 AM
VancouverXJ6's Avatar
Second the o2's
though your engine is different the concept is the same, when I did my o2 sensors it was the difference between slug and sport mode. Now the engine sounds better to.
Old Oct 27, 2020 | 11:01 AM
Chitty's Avatar
Thanks VancouverXJ6, That sounds like positive results to me
Old Sep 29, 2022 | 03:48 PM
ptjs1's Avatar
Posted in error
Anant
Sep 17, 2024 10:51 PM
Rick Mules
Mar 29, 2020 05:21 AM
scotott
Nov 15, 2015 09:18 PM
oldmaned
Jun 21, 2014 09:19 AM
georgia boy
Jan 26, 2011 08:47 AM
