Coolant temperature sensor
My 94 xjs 4.0 runs better with TCS unplugged?
replaced: coil, thermostat, TCS, fuel filter, no corrosion on any electrical plug.
if the TCS is plug in the engine is sluggish, unplugged engine is very responsive and fast
what is going on?
what is going on?
i think the TCS holds the idle solenoid open for cold starting, and should modulate/close the idle solenoid when up to the desired idle setting
if the sensor is wrong it could be closing the solenoid prematurely or all the time ,
does it run well when fully up to temp even with the sensor plugged in
BB
BB
Old oxygen sensors could be lazy and provide you with a sluggish responding car. When was the last time they were changed?
Anant
Sep 17, 2024 10:51 PM
oldmaned
Jun 21, 2014 09:19 AM
georgia boy
Jan 26, 2011 08:47 AM
