Cooling bleed pipee
Old Aug 1, 2021 | 02:34 PM
rgp's Avatar
rgp
Default Cooling bleed pipee
May be a bit complicated for this forum but,.. Is it o.k.to increase the diameter of the right hand side small diam pipe that comes from the banjo and connects to a stepped hose and joins to the crossover pipe filler? I ask this as its always this small tube that clogs when laid up for the winter. Or is this also a venturi?
Old Aug 1, 2021 | 09:37 PM
No reason I can see or think of.
There was a one valve report to be in that section near the fill spout, I have never seen that valve in any of mine.
The banjo cross drilling error, especially with "standard" copper washers, is the main cause of restricted flow that I have found.
We dont store for Winter, or any other season, so I have NO experience with what happens there.
Old Aug 2, 2021 | 12:44 AM
Greg in France's Avatar
Quite OK, nothing to do with the venturi. Great idea too.
TropicCat
May 21, 2021 10:26 AM
rgp
Apr 26, 2021 07:07 PM
Rondog
Nov 29, 2020 05:31 PM
Rhett
Aug 14, 2014 10:47 AM
