Couldn't find code
Old Oct 17, 2022 | 08:09 PM
93xjs6cyl's Avatar
Default Couldn't find code
After cleaning my throttle body I am now getting code FF26. Anyone know what this is and what I should do?
Old Oct 17, 2022 | 08:54 PM
93xjs6cyl's Avatar
My manual says code "26" says it's an air leak, but it does not have a "FF" before it.
Old Oct 18, 2022 | 08:45 AM
Vee's Avatar
Vee
Have you tried searching this forum, using FF26 as the keyword?
Old Oct 18, 2022 | 09:29 AM
93xjs6cyl's Avatar
So, I saw where someone said it meant Fuel fail "26". Meaning probably an air leak.
Old Oct 18, 2022 | 10:01 AM
Vee's Avatar
Vee
Guess you should look for an air leak then.
What I typically do is seal the MAF off with some plastic wrap and light up a cigar and blow smoke in through the hose that goes into the intake elbow from the engine camcover. You want to make sure that the plastic wrap EXCLUDES the MAF from the cigar smoke, since anything before the MAF is unmetered anyways, so a leak upstream of the MAF is useless. Basically the smoke should go (1) up towards the MAF, but get blocked off by the plastic wrap, and (2) into the intake manifold/engine.
Old Oct 18, 2022 | 11:33 AM
93xjs6cyl's Avatar
I had found this large leak and thought I had fixed the problem, but the plastic was determined to stay bent in. So, I had to glue this small area together. Hopefully, it should be fine now.
Old Oct 18, 2022 | 12:02 PM
Vee's Avatar
Vee
Personally, I'd replace that part. Should be easy enough to find on eBay.
Old Oct 18, 2022 | 12:17 PM
93xjs6cyl's Avatar
It looks good now. If I need to I will.
Old Oct 18, 2022 | 12:26 PM
Vee's Avatar
Vee
It looks like a mess on both ends! The rubber accordion looking thing looks like its in bad shape, and the elbow....someone really cranked down on the hose clamp.
Definitely worth smoke testing that thing when it's back on the car. Any air leakage there will cause problems.
Old Oct 18, 2022 | 05:08 PM
93xjs6cyl's Avatar
I was looking for an air leak before I got the code. I wasn't getting a code before, but at idle I was having a slight stumble. As some of you already know, I bought a couple of sensors and cleaned up a ton of electrical connections. When I took it down to the throttle body, I saw how dirty it was so I decided that I needed to take it off and clean it up. It had about 1/16" of sludge on the inner walls and about another 1/16" - 1/8" along the outer edge of the butterfly. Theres no way it could have been sitting at .002" at any time. After a good cleaning, I put it back on the car. I checked it for the .002 and it was slightly off maybe around .004". Now it is at .002 and the air leak is resolved. I never at any time touched the TPS adjustment. Cold, it started right up and it was idling at 700-725 rpm and in gear at about 600-625 rpm. I just let it idle and think for a few minutes. Now there is no stumbling at all and maybe it's my imagination, but the engine seems a bit stronger. Again, maybe my imagination, but it sounded a little healthier also. It feels a little strange sitting in the car and feeling the engine instead of the stumbling. I still need to take her out for a ride for my final conclusion, but so far so good.
Jon89
Jan 29, 2019 11:44 AM
Diywannabe
Jun 12, 2017 06:59 PM
Wewillbfree
XJ40 ( XJ81 )
Apr 25, 2017 06:22 AM
Spikepaga
Dec 4, 2014 01:34 AM
SteveJacks
Jul 2, 2014 08:34 PM
