Crank Sensor Plug And Socket Photo Wanted Please
Old May 13, 2019 | 03:36 PM
orangeblossom's Avatar
Default Crank Sensor Plug And Socket Photo Wanted Please
Hi Guys
Does anyone have a Photo or a Diagram of where the Electric Plug and Socket for the Crank Position Sensor Plugs in XJS V12
Old May 13, 2019 | 07:49 PM
warrjon's Avatar
The cable goes up the front of the engine, there is a cable clamp near the bottom rad hose. It is very hard to see with the fans in the car. You will need to look from underneath. I can not remember where the connector is but I suspect near the AC compressor
Old May 14, 2019 | 04:00 AM
Dukejag's Avatar
I went to see if I could see it from under the car and NO...
Could not find it to take a picture.
Old May 14, 2019 | 04:53 AM
Hi Duke
Me neither!
But I'll find it, although the Wire from the VR Sensor does not look as if its been hit or damaged by the Alternator Belt when it broke up
Though having said that when it did break up, there were multiple strands like Spun Sugar wrapped around and in the Gap between the Crankshaft Pulley and the Engine, that when removed you could quite clearly see had really shined everything up
Not sure if that's significant or what?
Although the Snapping Alternator Belt has certainly cured any fears I've had of the Engine overheating! (And Flying!)
As if the Alternator Belt Snaps like it did on my Car, then it could really put your life in Danger
So if you ever get to see the Alternator Light come on, you need to get off the road as quick as you can and then remove that Broken Belt before it hits the VR Sensor and suddenly cuts the engine out without any warning!
romroc
Aug 1, 2017 06:52 PM
DrScientist
Sep 1, 2015 09:19 AM
1100me
Oct 27, 2014 03:55 AM
Grant Francis
Sep 27, 2012 06:28 AM
hawaiianjag
Oct 8, 2010 06:02 AM
