Cruise control problem
Old Aug 11, 2013 | 01:34 AM
hbwjag's Avatar
Default Cruise control problem
Hi all,
I would appreciate any help regarding an issue with my cruise control, it works fine, sets, increases speed & disengages, but will not resume after a disengage, however it will again allow me to set a speed.
To me it would appear that the mechanical side is okay but the electrical side has a fault.
Any ideas please?
Old Aug 11, 2013 | 06:19 AM
Doug's Avatar
Dirty/faulty contact inside the "resume" switch? Or poor wiring connection at the switch?
What year and model?
Old Aug 12, 2013 | 04:00 AM
hbwjag's Avatar
Sorry about that, I was in too much of a hurry!
1989 V12 HE
I did briefly check the switch but I'll have a much closer look at it and test it properly as you suggest.
Thanks.
Old Aug 12, 2013 | 07:42 AM
Doug's Avatar
It might help you to know that it's the black/slate wire that gives the "resume" function. With the switch pressed to "resume" the wire should be grounded/earthed
Often the switch can be (gently and carefully) opened up to clean dirty contacts. If you determine (or even suspect) the switch is at fault you might give it a go before spending money on a new one
Old Aug 13, 2013 | 12:44 PM
hbwjag's Avatar
Excellent, I'll do that.
XJsc-guy
Sep 25, 2015 11:09 AM
Skeeter
Sep 17, 2015 08:15 PM
edtexas
Sep 4, 2015 08:20 PM
laserguy
Sep 3, 2015 02:02 PM
XFR_Gold
Sep 2, 2015 12:24 PM
